Draining Tranny Fluid?
Old May 14, 2004
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Hey everyone, I tried to change my transmission fluid today following the DIY I found on the site. I found the right bolt, but for some reason the bolt, which I was pretty sure was the right bolt because it was the one by the subframe and the only one with the washer on it, was completely round, not square like the DIY said. There was something in the middle of the bolt that felt like I tool could fit in, but I was not sure what type it was. Maybe an allen wrench or something. But anyways, I'm just going to take it to a professional to get it replaced, but use the fluid that I bought. Does anyone know for future reference how I get the bolt off? Also, if I use Mobil 1 Synthetic ATF, how long will this stuff last before I have to replace it? Thanks.
Old May 14, 2004
tuffy7's Avatar
tuffy7 is an unknown quantity at this point
Hi ZSXCivic01:
Yes, the bolt (drain plug) is round. In the center of the plug is a 3/8 "
square depression that you can use a 3/8" drive ratchet or breaker bar to remove. I hope this helps on your next fluid change.
Also, be sure to use HONDA Z1 fluid. Hope this helps. Tuffy7
Old May 14, 2004
ZSKCivic01's Avatar
Extreme Member
Im just going to get it done professionally. I think it is best to get the entire transmission drained, torque converter, etc.
May 4, 2016 07:14 AM
JetsterDajet
Aug 15, 2015 08:07 AM
Drix
Aug 14, 2015 11:41 AM
Q-Bert
Jul 19, 2015 09:09 PM
Jul 12, 2015 11:54 AM
