Suspension + Fuel Efficiency
Old May 3, 2004
t3a5p00n's Avatar
t3a5p00n is an unknown quantity at this point
Hi. I plan on getting a HX Coupe some time in the far future but like to do my research early.
I'm just wondering if lowering a car can improve fuel efficiency. I want to either get '04 EX alloys or the '01-03 EX alloys or '99-00 Si alloys. I know tire size and correct pressure and other stuff factors in, but suspension wise, Can it help gas mileage or will it hurt?
I want the HX Coupe for the gas mileage but also love the look of a lowered 7th gen with those above mentioned alloy wheels.
Thanks.
Old May 3, 2004
Mr.Modify's Avatar
never heard of suspension helping out gas mileage!?!?!?!?!!?!?!?
Old May 3, 2004
tripledoublegs's Avatar
Euro-Spec
damn dude, youre going overboard with this fuel efficiency crap. The hx gets like 44 mpg, you don't think that's enough??
Old May 3, 2004
HondaLuver's Avatar
Its a celebration bitches!
actually it does, the lower your car the less air that travels under the car which can slow you down by creating diffrent currents under it...
you become more arrow dynamic when lower
Old May 3, 2004
ponyman's Avatar
ponyman is on a distinguished road
So does that mean that midgets are more aeroynamic than normal people????
Sorry I couldn't resist
Old May 3, 2004
HondaLuver's Avatar
umm, in theory
Old May 3, 2004
t3a5p00n's Avatar
haha, i guess i am taking it to extremes but i was just wondering.
those 99-00 si alloys or 01-03 EX alloys are not heavy right?
Old May 3, 2004
HondaLuver's Avatar
not as heavy as 02 si's i think you save about 4 pounds with the old ones, i like the older ones better
Old May 4, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
LMAO i nearly fell outta my chair
Old May 4, 2004
jttegx's Avatar
OMNES AD UNUM
will lowering actually make a difference to gas mileage?
even if it does, i bet its like barely noticeable either if its in a bad or good way.
Old May 4, 2004
robbclark1's Avatar
Retired suspension supermod.
I might make a small difference but not much to tell, maybe a few extra miles. In theory it should make your more aerodynamic like hondaluver said.
Old May 4, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
The front of the car still has the same surface area. You're knocking off about an inch or 2 of vertical tire area so say, 12-30 sq inches taken out of the frontal area which is many square feet. The air drag may go down an itty bit. Not enough to make a significant difference
Then you're putting heavier wheels on with fatter tires.
And you're taking this a little too far. If you're lowering it, just do it, **** the gas milage.
Strycker
Aug 2, 2015 08:40 PM
JKWood
Jul 28, 2015 03:45 PM
Green02civic
Jul 27, 2015 10:48 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
