My 9833 headunit wiring......Help Please
Old May 1, 2004
Ringyu's Avatar
Ringyu is an unknown quantity at this point
Hello all! I've searched around this forum, but I want to be sure I wired my headunit correctly.
This is what I've done.....and for those of you with experience in this area, please let me know if I've wired my headunit correctly...
Ok, first of all, I have a 2001 civic hx coupe, my headunit is the Alpine CDA-9833, my wiring harness is the Scosche wiring harness (model HA08), and I am using separate amplifiers (i.e. I will not be using the headunit's internal amp).
Unless I'm wrong, the only wires that come off of the Headunit that I need to use are:
1) Battery Wire (Yellow), which I connect to the yellow wire on the scosche harness
2) Ignition Wire (Red), which I connect to the red wire on the scosche harness
3) Remote Wire (Blue), which I will wire to my relay
4) Ground Wire (Black), which I will ground directly to the metal bar behind the dash
I used electric tape to tape off the rest of the wires coming off the headunit (i.e. All 8 of the Speaker wires, the Power Antenna wire (blue), the Audio Interrupt In wire (pink), and the Illumination wire (orange)). In addition, I taped off the rest of the wires on the scosche harness.
Does this sound right to you guys?
Any help would be Greatly Appreciated!! Thanks!!
Old May 1, 2004
Ringyu's Avatar
Anyone with any useful knowledge/experience with wiring headunits...please let me know if I'm wiring my headunit correctly. I would really appreciate it!! Thanks!!
Old May 1, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
I would connect everything but the speaker wires.
Old May 1, 2004
If you have a glass mount antenna on the rear window, then you must hook up the power antenna wire to get good reception. I forgot, so now I can't listen to FM or AM. Illumination wire you could do also if you want the deck lights to dim with the other dash lights.
Old May 2, 2004
Ringyu's Avatar
The Power Antenna Wire on the vehicle harness is the Yellow/Green Wire right?
PS2Wayne
Jul 15, 2002 12:46 AM
ZSKCivic01
May 7, 2002 02:41 AM
djaber
Mar 28, 2002 01:12 PM
Foom
Dec 6, 2001 01:11 PM
