KMS intake manifold + SF
Old Apr 28, 2004
RedDragon333's Avatar
What are your thoughts on using the KMS intake manifold with the SF kit. I was one of the fools that learned the hard way on this thing but the runners are very short and i know that on a NA application you actually lose power but on a FI any thoughts on how it would perform. Would it be worth using it or leaving the IM stock
Old Apr 28, 2004
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
ive got the KMS im with sf kit... never got it dynoed before my engine blew lol... but ill have some numbers within a month or so with the sf kit and kms im...
also here:
http://www.7thgencivic.com/forums/sh...72#post1988272
Old Apr 28, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Shorter runners are notorious for helping FI applications. Shorter runners help airflow on higher rpms but you end up losing intake velocity at lower rpms (hence less torque). You usually need a cam with a higher powerband and larger lift and duration to better utilize the intake, but obviously it's not required....
I think if you match the IM and SF kit, you should be quite happy....
Old Apr 28, 2004
RiceBuRNeR's Avatar
Turbo Member
it should work well w/ your application. I should have my DH manifold in about a week.
Old Apr 29, 2004
Havok what do you mean match the IM with the SF?
Old Apr 29, 2004
Havok2k1's Avatar
Wicked Pissah Admin
If you use the Intake Manifold and Stafford Kit together you will be happy with it....
Old Apr 30, 2004
Civryder02's Avatar
Civryder02 is an unknown quantity at this point
dyno it and post the numbers
Old Apr 30, 2004
Still debating if im gonna install it.
Old May 1, 2004
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
do it
Old May 1, 2004
lmao MAYBE I WILL lol
Old May 1, 2004
K20me's Avatar
FINE do it then!
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
kevfarr
Sep 18, 2015 02:28 PM
