how to reqire wire harness for new gauge cluster
Old Apr 25, 2004
skarteez's Avatar
skarteez is an unknown quantity at this point
ok i know that SI/RSX gauge clusters have different harness for the wires and hookups. people have said that if you get a wiring diagram, you can rewire the Civic harness to adapt to the different gauge cluster harness.
ok knowing a little bit more about wiring after some snoopin around the site and my ECU harnesses, i wanna clarify my thinking to see if im right or not.
so the actual plugs are different for the RSX clusters. so would i have to get rid of the plugs on the Civic harness and get one that matches that of the cluster? then woudl i have to pull each wire out individually out of the Civic harness and, following the pin diagram of the civic/RSX, match them up? like wire for tach needle control from civic has to match up to the tach needle control wire to the RSX cluster? am i makgin sense?
it would be helpful if anyone could clarify this for me. thanks!!!
Old Apr 25, 2004
Your cluster is good the way it is. It's gonna be a big hassle swapping from a different car. Even with wire pin diagrams for both cars (if you can find them), there may be differences in signal protocols. Assuming they are compatible, you're gonna have to match each wire pin by pin.
Old Apr 25, 2004
cosmo's Avatar
cosmo is an unknown quantity at this point
Gearbox beat me too it, if you change yours out can I buy your old one?
Old Apr 26, 2004
skarteez's Avatar
hehe it was just out of curiousity yeah the switching out pin by pin was the answer i was looking for.
i love my gauges!!!!!!!!!!!!!!
Old Apr 26, 2004
acidbaby's Avatar
The Beez Kneez
yes
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Jon-Ohio
Jun 30, 2018 08:10 PM
Ma213802
May 18, 2015 07:01 AM
nicholaai
Apr 27, 2015 05:54 PM
