Help with header install!
Old Apr 23, 2004
Exclamation Help with header install!
I can't get the heat shield bolts off. I already broke a socket, and now the bolts are starting to strip. Any ideas? I tried spraying with pb blaster, but it doesn't work. I even drove the car around to make them hot. Nothing.
Old Apr 23, 2004
Bolts are stripped. Now what do I do?
Old Apr 23, 2004
djmota's Avatar
If they are truley stripped, I would go the gorilla route and drive the car around again hard to heat everything up, bend the heat shield away from the bolts on the header and take the header and heat shield off as one piece. The bolts on the head may be difficult also. Make sure to only use proper sized sockets or the closed end of a wrech to break those free.
The spring bolts underneath should not be so bad.
Old Apr 23, 2004
The heat shield will just bend away? So does that mean the heat shield bolts don't need to go back on?
Old Apr 23, 2004
snowboreddave's Avatar
snowboreddave is an unknown quantity at this point
that is correct. your heat shield will not fit over the bigger pipes of the aftermarket header.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
