Does anyone know the weight of the stock flywheel??
Old Apr 21, 2004
vipergtsr's Avatar
vipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trusted
I am going to replace my stock clutch with an ACT extreme performance stage 1 clutch. I am also planning to replace my stock flywheel with an XACT 11.7lb flywheel or a Prolite XACT 8.2lb flywheel. The differance is $24 and i am trying to decide if there is a benefit or a disadvantage to go with the lighter flywheel. So I am trying to compare the stock flywheel to an aftermarket one. So if anyone knows the weight of the stock on it would help me. Also does anyone have either of these flywheels.
Just a note. It is going into a '02 EX and the olny mod I have is a greddy cat back, and no more mods are planned
Old Apr 21, 2004
nivenmk1's Avatar
nivenmk1 is an unknown quantity at this point
I thought I heared mentioned that the stock flywheel on the D17A2's was somewhere in the 20-25lb neighbourhood. I could be a slight bit off on that.
DH racing resurfaces/shaves stock flywheels, I'd give them a call and see if they can offer you any help, unless someone else knows.
Before you buy, check the rated RPM on the flywheels. Maybe I'm just overly-paranoid, but having a shaved flywheel come apart beause I didn't check on something is a bad way to wipe your ride.
Old Apr 21, 2004
robbclark1's Avatar
Retired suspension supermod.
Stick to the 11lbs one. I personally think 8lbs is way too light. You won't be able to transfer the power correctly.
Old Apr 21, 2004
WhiteCastle's Avatar
DH racing those paper weight bastards?? psssh hell no don't buy thier crap
Old Apr 21, 2004
Intruder's Avatar
Intruder is an unknown quantity at this point
I had the Streetlite flywheel for a bit over a year. It was a large improvement in throttle response, it also lead to quite a bit more vibration at idle though. I would stick with the streetlite flywheel if I were you. The lighter a flywheel is the more prone it is to warping/grenading (mine was warped after 12,000 miles) so I don't think the benefits outweight the risks of a reall light flywheel.
Old Apr 21, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
the good side of the lighter flywheel is that the motor revs up faster but on the downside it also loses up momentum fast so rev matching is gonna be a little more challenging if you do that
Old Apr 21, 2004
Macfay's Avatar
Macfay is an unknown quantity at this point
yes...StreetLite is enough...but no virbation for me though...
it just you need to give a bit more gas on startup...
OptimisticWay
46
Oct 15, 2015 02:16 PM
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
