AC Belt removal
Old Apr 15, 2004
civicex2002's Avatar
civicex2002 is an unknown quantity at this point
AC Belt removal
I need to replace my AC belt because it is squeeking bad. Is there a tensioner or does something have to come off? Thanks
Old Apr 15, 2004
cdmx's Avatar
loosen the a/c bolt thats holding it on then unscrew the tensioner with your thumbs or some pliers and that will untighten the belt.
Old Apr 15, 2004
Agent9's Avatar
Agent9 should not be trusted
so you can install/uninstall it as needed? is it worth it to take it off?
Old Apr 15, 2004
Agent9's Avatar
I think it will free up like a huge 1-2 hp
Old Apr 15, 2004
cdmx's Avatar
Its not that big of a deal....all you need to do is loosen it and kinda pry it off the crank pulley
Old Apr 16, 2004
PacSmalls's Avatar
PacSmalls is an unknown quantity at this point
yeah it is pretty easy
Old Apr 16, 2004
sakabatou's Avatar
sakabatou is an unknown quantity at this point
Just take the ac belt and check for any damage or crack. But most of the times if your car is less than 70km you will just need to adjust the tensioner. Just be care full not to make it to tight. If you don’t know how tight to make it just keep on adjusting until the sound goes away and ya don’t start the car will adjusting the belt.
mohawkboom
67
Aug 25, 2015 12:28 AM
159
Jul 5, 2015 09:54 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
