Rattling noise front of car?
i had skunk2 coilovers on my car, and now im going back to stock. well i put everything back on but for some reason theres a really loud rattling sound from the front of the car now. seems like its coming from the top of the strut tower and only happens when i go over a bump. shocks arent blown because i just got new ones. i was just wondering if someone could post up a diagram of how the oem struts are assembled to make sure that i put everything on there in the right order? thanks.
Make sure they are indexed correctly. There is a thread about that, just search for it. Also, go back and retorque ALL the bolts.
yeah, i retorqued all the bolts, and i found a diagram and i have all teh stuff in there in the correct order at least. ill go check out if its indexed the right way, i though i put it in correctly.
I need TP for my bunghole
when I took my spring off I thought I had all the nuts and bolts tight and found that the passenger strut hat wasn't on tight. the center nut needed to be tightened a little more.
ok so i checked both sides, the right side was way off from being lined up right, so i fixed that, and the left side was just barely off so i fixed that too. but now for some reason the left side still makes a clunking noise but its not as bad as before. any ideas? all the bolts are on as tight as possible, and the little bearing/bushing plate is in the correct slot so i cant see how it could be moving around or anything.
! Thread Starter
hey, is there any way to rotate the top spring perch without having to take the strut tower completely apart? the damn spring pushes up with a lot of force so does anyone have a way of compressing those? the compressors that i got from autozone wont do the job, they suck really.
usajags84
15
Aug 19, 2015 03:12 AM
GH04si
Apr 15, 2015 08:13 PM
Russps
Nov 8, 2001 02:00 AM
