problems with downpipe and cat.. installation
Old Apr 6, 2004
bakablo's Avatar
bakablo is an unknown quantity at this point
I cant install a downpipe with a h/f cat converter..
the problem arises at the bolts that bolt together the headers and the downpipe... the bolts have these little "springs" with them.. I cant loosen them p... Ive sprayed wd40 but no luck.. any suggestions greatly appreciated.. thanks guys
Old Apr 7, 2004
djmota's Avatar
start the car and let it run for a while. doing this will heat up the bolts and make them easier to take off. Then give it a shot ... but don't burn yourself.
Old Apr 7, 2004
cdmx's Avatar
Dude your trying to take the bolts off from the bottom of the header right?
Old Apr 7, 2004
djmota's Avatar
thats what it sounded like to me. Wierd because they aren't that hard to loosen up.
Old Apr 7, 2004
gipperkid's Avatar
gipperkid is an unknown quantity at this point
Yes, be careful not to snap the bolts off in the bottom of the manifold. Get some PB Blaster and soak the bolts.
Old Apr 7, 2004
bakablo's Avatar
ahh.. I just took it to a muffler shop.. they did... thanks anyways gus.. I appreciate the help
Old Apr 7, 2004
bakablo's Avatar
and yah it was the ones on the bottom.. there arent any at the top
Old Apr 8, 2004
cdmx's Avatar
there are nuts at the top some ppl might get confused and try to lossen...but they are welded in there
Youshoe
May 22, 2015 09:36 PM
ej8
Apr 13, 2015 06:36 PM
Flatlander
Nov 16, 2001 05:38 PM
trevor
Nov 16, 2001 05:02 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
