My Car is loosing power
Old Mar 29, 2004
Jaykuai's Avatar
ish...
I know our car is not a torq monster but my car is loosing power..
at first i noticed the loss between 2000 and 3000rpm, the car takes so much time to move there, and it feels like i clutch in some times (clutch slipping?).
now its worst.. when reaching 5000rpm the car dont revs as fast as it was going.. it slows down.. this in gears 3 and 4, cant test 5th lease:
The car was not like that, this came with the transition from cold weather to a very hot one..
Old Mar 29, 2004
deciuss's Avatar
Boosted Auto
my a/t was losing power i just changed the fluid cost me like 15 bucks for the fluid very eazy and my car got back all its power its nice now.
maybe change your fluid?
Old Mar 29, 2004
invasian's Avatar
invasian is an unknown quantity at this point
maybe someone else wtole your power and put it in their car?
Thats what happened tp mine.
Old Mar 29, 2004
Jrfish007's Avatar
I don't know, that's a tuff call with out actually seeing the car, btu check all you fluids. See if any are diclored or anything. If you can take off,say around 2000 RPM in 1st and feel a pull, than it's probably not the clutch, but like I said, hard to tell. Give us some more details, maybe we'll come up with something.
Old Mar 29, 2004
Try some maintenance stuff. New air filter, plugs, and tranny fluid change. You could always get the hyper voltage system. It gave me back some torque.
Old Mar 29, 2004
Jaykuai's Avatar
ish...
the car is going to reach 30,000 km, i think i will take it to service at honda, i will see what they say..
i have abused the car so much.. complete days at drag strip.. 20 average races a day.. i just hope the drivetrain is ok..
Old Mar 29, 2004
invasian's Avatar
^^hummm...i wonder why...?
Old Mar 30, 2004
Jaykuai's Avatar
ish...
i just added that because my clutch may be slipping..
Old Mar 30, 2004
You should be able to do most of that stuff yourself. Try techron fuel system cleaner, check plugs, and check air filter. VERY easy. Upgrade your factory ground wires, too. Couldn't hurt.
Old Mar 30, 2004
WhiteCastle's Avatar
^lack of power can be related to a vacuum line problem. There could be a leak causing the lack of power since your engine is basically sufficating. I would check that first, i have expereinced it first hand in a BMW.....
remember if problem persists stall can occur.
Tedverseti
Apr 23, 2020 01:45 PM
darwin-t
Apr 18, 2015 09:29 PM
SSMatey
Apr 13, 2015 06:09 PM
thesushiboy
Apr 12, 2015 02:54 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
