reseting ecu
Old Nov 1, 2001
AnotherDopeStyle's Avatar
AnotherDopeStyle is an unknown quantity at this point
i was reading an article about reseting the ecu. which is necessary when replacing the intake, exhaust,headers, etc. how would i go about do this?
Old Nov 1, 2001
slikor's Avatar
slikor is an unknown quantity at this point
i think you just turn the car off and disconnect the battery (just disconnecting the red terminal should work fine) for like 5 mins. that should do it [IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Nov 1, 2001
AFlyer's Avatar
AFlyer is an unknown quantity at this point
A) Open the fuse box in your engine compartment and look on the diagram for the F.I. ECU (7.5 amp fuse)
B) Pull the fuse out and wait 10 minutes or longer.
C) Put the fuse back in.
D) VERY IMPORTANT - Start the car, and DO NOT touch the gas peddle!!!
E) Let the car idle for about 10 minutes, DO NOT toch the GAS!!!
F) Turn off car.
G) Turn on car, and turn back off.
H) Turn back on, and make some noise!!!
Old Nov 1, 2001
ph0ng's Avatar
ph0ng is an unknown quantity at this point
All of this previous info has been aquired by doing a search on the forums. I know some of you are lazy (me), but try it out sometime.
If you don't reset your ECU, it'll reset over time (don't know exactly how long). It basically balances your Air to Fuel ratio, giving optimum performance.
Old Nov 1, 2001
ALLMAN's Avatar
ALLMAN is an unknown quantity at this point
Again, I realize your new, so please search...You'll find all you'll need for this modification..Peace!
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
lowlife9
Oct 6, 2015 04:39 PM
senicalj4579
Oct 2, 2015 10:03 AM
Hutch1051
Sep 29, 2015 09:20 AM
ttamrekab
Sep 28, 2015 01:22 AM
