shaving trunk lock?
Old Feb 20, 2004
shaving trunk lock?
I've been wondering if it's easy to shave the trunk hole without painting the whole lid. Is it easy to take out the lock? I never open my trunk anyway, and I'd rather not have it there. Thanks for any input.
Old Feb 20, 2004
robbclark1's Avatar
Retired suspension supermod.
it can be done, but the paint won't match. That is why you should paint the whole trunk to match the paint with the rest of your car. You can take it out, fill it with bondo and paint over it, but if you want a good look, I suggest getting the whole think painted.
Old Feb 20, 2004
7thGenerasianCivic's Avatar
I'm guessing it's going to be the same process like shaving the two holes from the H. Same principle. So LOCKED
Old Feb 20, 2004
Thanks everyone. Is it easy to pull out the lock?
Old Feb 20, 2004
SquirrelCivic's Avatar
SquirrelCivic is an unknown quantity at this point
i shaved mine off already. just welded a little piece of sheet metal in the hole after i took out the lock , and then filled it with fiberglass filler. i went on and painted the whole trunk . it's too hard to blend the paint otherwise. the lock is easy to take out . just two bolts in the lock part and a clip holding the rod on the latch .
Old Mar 22, 2004
How did you paint it to match the rest of the car? You work for a bodyshop?
fvckbg
Oct 20, 2016 07:37 PM
Sep 27, 2015 11:33 AM
aaronmechanx
Sep 14, 2015 08:45 PM
nixyfior
Sep 14, 2015 08:32 PM
First Car
Sep 8, 2015 08:54 PM
