** HELP **I've searched and searched.......
Old Feb 12, 2004
BIG's Avatar
BIG
Exclamation ** HELP **I've searched and searched.......
Ok I've done about 2 days worth of searching and I still have questions.
I currently drive a 2001 Lx Coupe
I purchased:
HP 4-1 Race header with high flow 'cat'
GReddy Evo II cat back
Progress 27 mm front sway bar
now from what I have read my Progress front sway bar might not fit. I searched Grey's posts and I think he got his to fit. My Progress bar is the grey one, not the puke green one. does that make a difference?
Sorry if the answer was right in front me me, but I don't know if everything will fit.
Also,
What exactly do I use to extend my o2 sensor wires
What is the 'O' ring needed? and where does it go?
Is there anything I'm forgetting?
Old Feb 12, 2004
BIG's Avatar
BIG
anyone?
Old Feb 12, 2004
abmerop18's Avatar
Jam out with your clam out.
just purchase EX o2 sensor wires from www.hondaautomotiveparts.com and they will plug right in.
the sway bar will fit. the only difference between LX and EX i think is either the design or the size, but either way im positive the mounting points are the same and it should fit.
Old Feb 12, 2004
azure's Avatar
The difference between the LX and EX front sway bars is the curve in the middle. If I remember correctly, the curve for the EX front sway bar is a little wider than the curve for the LX so that it can fit the cat converter.
Wait, were you asking if the front sway bar will fit. . . as in, bolt right on? Or, if it will fit with the cat underneath?
Old Feb 13, 2004
BIG's Avatar
BIG
ok, sorry, let me clarify...I am asking if everything will fit with the Progress front sway bar
Old Feb 13, 2004
BIG's Avatar
BIG
bump!
Old Feb 13, 2004
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
Yo, dunno about the sway bar dude, but by the o-ring Im guessing you are referring to the donut gasket? they're about 40 bucks from a muffler shop. I made my own of course, out of aluminum foil hehehe.
Old Feb 14, 2004
BIG's Avatar
BIG
yeah I'll have to go buy one
I really wnat to know about that bar tho
Old Feb 14, 2004
robbclark1's Avatar
Retired suspension supermod.
No one will know if it will work with that set up. Progress redesigned the front sway bar to fit all 7thgens. I would say get the sway bar first and work around that. It is easier to do custom pipes than to custom a sway bar. you can have your pipes bent to go around the sway bar. If you plan on getting the progress rear sway bar, I suggest getting the greddy bent also because it will tap agains the sway bar.
Old Feb 14, 2004
BIG's Avatar
BIG
I already have the Progress Rear Sway bar......oh man, how much does the GReddy need to be bent
Old Feb 14, 2004
Pharoh's Avatar
Bobaganoosh!
Yup. I bought all three peices at once. The front bar was the charcoal colored one and the rear was green. Both fit fine, as they should since they market it for the SiR HB/ 7thgen coupe/sedan and RSX.
The pipe on my TCS touches a tiny bit on the rear bar but only for a couple of minutes when the car is cold. After that you almost never hear it unless you hit a pothole or something.
Old Feb 14, 2004
robbclark1's Avatar
yeah but you have the TCS and not a hp header and downpipe. He is more concerned with the front not hitting. But like pharoh said, it might bang more when it is cold and may stop. but I don't know what it is like with the greddy. It won't have to be bent that much. You can sometimes put a buffer in between them, but a more permanent fix would be to have it bent.
Old Feb 14, 2004
Pharoh's Avatar
Bobaganoosh!
I wish this was from a different angle.
Old Feb 14, 2004
BIG's Avatar
BIG
is that your car?
Old Feb 14, 2004
Pharoh's Avatar
Bobaganoosh!
Originally posted by Big
is that your car?
Yes. Last year
Old Feb 14, 2004
BIG's Avatar
BIG
nice, ok my progress front and rear are charcoal, does that make a difference??
Old Feb 14, 2004
Pharoh's Avatar
Bobaganoosh!
I don't think so...my front is charcoal and it's fine.
Old Feb 14, 2004
BIG's Avatar
BIG
ok sweet, now I'm not really that worried.
do you have an o2 sensor or simulator? Do you have your CEL on?
Old Feb 14, 2004
Pharoh's Avatar
Bobaganoosh!
I have an o2 sensor. I don't have an aftermarket downpipe like you. I have the DC header. Still though, I don't see a problem with it.
You have to remember one thing. They gurantee those bars to fit the car. Not the car with other than OEM parts on it. Still, I think you'll be ok. If I could I would get a pic of the front bar for ya.
Old Feb 15, 2004
BIG's Avatar
BIG
Yeah pics would be sweet!
Do you have your CEL coming on? Do you have after market Cat?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
winanthony94
Sep 25, 2015 09:05 AM
chiquita.banana
Sep 24, 2015 09:42 AM
meicalnissyen
Sep 22, 2015 06:20 PM
