for sale.. turbo and engine!
i dont have a set price yet, but i have a d-17 motor with 14,000 miles on it.. with a turbo specialties turbo kit on it (turbo kit has 1500 miles on it) its a ball bearing t3-t4 turbo.. comes with manifold.. intercooler.. fuel injectors.. computer.. all neccessary wires and lines.. engine and tranny included.. im looking for 4000.. i could lower it depending on the offer.. its a great deal.. email me at bangincivic23@aol.com for info.. the turbo kit was 3000 and 1000 to install.. new tranny.. 14000 mile engine.. everything included along with the turbo kit.. if you just want the turbo kit or the engine.. i could do that.. let me know!
its made for all models.. it comes with an intercooler kit..
1 Turbo with cast iron manifold and wastegate (ball bearing)
1 Down Pipe with gasket
1 Injection Control Unit
1 Injector interface block with injectors
1 Blow off valve
1 Fuel pressure regulator
1 High flow intercooler w/ mounting hardware, pressure tubes, hose connections and clamps
1 Map unit (Black Box)
1 Oil Return Line and Fitting
1 Air Cleaner with Piping
this turbo is for all models and im getting rid of it because im upgrading to a k-20 with a turbo
1 Blow off valve
K20's are getting cheaper and cheaper now. Soon its under 10 grand for one with install , I will consider purchasing it. Hopefully around 6 grand!
yea.. im going to boost my k-20.. its going to be sick.. right now.. this engine holds 112 lbs boost no problem.. we did some internal work.. it has 276hp.. this is a decent turbo set up.. it has a boost controller.. so if you would want to.. you could change the boost.. engine and turbo for 4 grand.. cant beat it
after you get the instalation, unless you have the time to do it yourself its almost 10 grand. You cant just slide a k20 in, you need to reprogram the ecu, you need new axle with axle barings and etc etc
if your selling just the turbo kit for 2k, then ur basically asking another 2k for the engine and tranny, i think i can get a d17 for like $700 and i know of 2 5spd trannies sellin for $200. wheres that other grand come into play?
yea im seeing a price list as follows
COMPLETE DROP OUT (engine, tranny, ecu) 800 at the most
TURBO KIT 2000 at the most
WHERE IS THE 1000+ coming from............
NEWS FLASH
your not going to get anyone on here to pay to reimburse u for the labor that was put into ur car
NEWS FLASH
Supramk3
May 8, 2015 11:16 AM
cloudguy
Apr 28, 2015 05:02 AM
answers to all these frickin turbo, nos, and super questions- im RANTING!!!!!!!!!! PLEASE READ!!!!!!
pinkytoe
Jan 8, 2002 06:05 PM
