Car Jack Points
Old Feb 6, 2004
GoBruin02's Avatar
GoBruin02 is an unknown quantity at this point
Car Jack Points
I looked up a thread that said that I could jack up the front of the car on the tow hooks. I looked underneath and found two large steel ones, one towards each tire. I used this as a jack point. It seeme to work out ok. I'm just wondering if I jacked up the car on the wrong spot and if I did, then did I screw anything up?
Old Feb 6, 2004
tfnaaf's Avatar
BLDNPSI Mod
If you did jack in the wrong spot, YES its a possibility that something could have gotten messed up. Easiest way to tell is crawl under and take a look see !
Old Feb 6, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
On the front splash guard, there's a molded in arrow. It points straight at an extruded flat on the frame rail.... thats the front jack point.
The 4 points for lifting up the car 1 corner at a time are in the manual, and are just behind the front tire wells and just in front of the rears. They say you can jack up the whole *** end by the tow hook but I don't have a jack that goes that high... I've never had a problem lifting it by the suspension mount where the lower arms connect to the body.
Old Feb 6, 2004
XxSoVeReiGNxX's Avatar
guys tell me if i'm right; it's this thing right??
Old Feb 6, 2004
GoBruin02's Avatar
Yeah, but if you're putting your car on jack stands, you can't jack up the car in the location shown on the pic, since that's where the jack stands would go. There are other places to do it and I just want to check if where I did it was the safe one.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Tedverseti
Apr 23, 2020 01:45 PM
mikemc422
Aug 9, 2018 05:41 PM
mattdoc
Mar 14, 2017 12:10 PM
usajags84
15
Aug 19, 2015 03:12 AM
