Beading your charge piping....
Old Jan 28, 2004
opto_isolator's Avatar
Question Beading your charge piping....
Ok - so I just got my charge piping welded (looks awesome). Now I need to put some beads on the ends so they don't blow off under boost. The shop who did the welding didn't really have any idea who around here had the proper machine to make a bead. So does anyone have any ideas on making your own beads (or know of any places that might do it)?
Old Jan 28, 2004
HTOWNBOY's Avatar
HTOWNBOY is an unknown quantity at this point
I just TIG welded beads on my charge pipes.
Old Jan 28, 2004
wannabeblown's Avatar
wannabeblown is an unknown quantity at this point
True. Finding a place to actually bead the pipe is hard. If you don't have access to a welder. Then take some 80 grit sandpaper and rough it up a bit. Then mask off a stripe on the pipe, and put epoxy on the stripe. When its dry pull the tape off and you'll have a nice clean easy bead. Cheers
Old Jan 29, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
i am telling everyone, my SF kit is on it way. yippie
Old Jan 29, 2004
RiceBuRNeR's Avatar
Turbo Member
I just welded a beed onto my new home made charge pipes.
Old Jan 29, 2004
HTOWNBOY's Avatar
TIG welding beads on your charge pipe is as good as normally beading it. It worked for me.
Old Jan 30, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
if you have them powdercoated, you should not have to worry about them coming off. The rubber coupler on the powdercoating makes a very strong bond.
Old Jan 30, 2004
civicskater's Avatar
Chicks dig my scent
could someone show a pic of what the beads look like and where they're welded at? Would they be welded only by the intercooler and throttle body? Im confused, sorry, i just wanna make sure so i can get mine done and wont have problems
Old Jan 31, 2004
HTOWNBOY's Avatar
i welded the beads on all the ends of my charge pipes
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
haloway13
Nov 6, 2015 10:43 AM
Skunkone
Sep 24, 2015 04:38 PM
JMKendrick
Sep 16, 2015 06:17 PM
h4ldol
Sep 10, 2015 12:25 PM
