Projector to Stock Head light
Old Jan 28, 2004
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
What would i have to do if i want to put back my stock headlight i didn't install the projector.
but I know the light bulb is different so i am assumming the the wiring is different...
Old Jan 28, 2004
JayFReaZy's Avatar
nothing, just get different bulbs to fit the stock headlights. I know H4 is for low/high beam. Im not sure about the parking/turn signals.
Old Jan 28, 2004
jdm_bb's Avatar
But do i need to convert the wiring or sth? because stock headlight
is H4 for high and low beam and for the Projector is one for headlight and one for high beam..
Old Jan 28, 2004
dirtySAMURAI's Avatar
I log in from time to time
Your projectors should have come with a wiring harness that splits the stock wiring up into 2 different connectors. The 2 new connectors go to each headlight bulb for the projectors.
Old Jan 28, 2004
jdm_bb's Avatar
is the wiring harness in the projector just a add on to the stock..?
if i take that off i can put my stock headlight back on?
Old Jan 28, 2004
acidbaby's Avatar
The Beez Kneez
there is no modification for the projector, its a bolt on! just plug your headlights back in
you do have to take off the bumper though. there is a diy on the homepage
and a little button called search
Old Jan 28, 2004
civicvtec1ps's Avatar
Search and Learn
Yes, Projectors come with new wire harness.
Just take out wire harness then put stock headlights back on. Easy swap.
If you have any more questions. PM me.
I will get back to you asap.
Supramk3
May 11, 2015 07:55 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
cazminn
Nov 9, 2001 11:18 AM
sonsonzai
Nov 4, 2001 12:52 PM
