Driving w/o front sway, bad?
Si(R) killer # 1
I'm planning on doing the LX to EX exhaust swap in the next few days, and I was wondering if there is any harm from driving around without a front sway bar for a while until I find an EX front sway bar, since the lx bar will prolly have clearance issues with my fake cat.
Si(R) killer # 1
Thanks Philip, that's kind of what I thought, since adding a larger rear sway bar is good for cutting down on understeer - so removing the front sway bar should produce some oversteer. Of course both sway bars would be much, much better.
I have
- Front Uper strut bar
- Front Lower strut bar
- OEM Front swaybar
- RSX 19mm Rear Swaybar
- Rear Lower Strut Bar
... is that good or not??
What if i take out the all of those and change it back to OEM setup?? and what's the downside??
it's not that i want to race, but i just want my car ride feel better because right now my car feel like a little oversteer
Thank you kindly
- OEM Front swaybar
Thank you kindly
Si(R) killer # 1
Boilermaker - thanks for the input, I have ordered the progress rear and oem ex sway bars, but untill i intstall them i'll drive around without the front sway for a while to see how I like it. What setup have you found to work best for auto-x?
Originally posted by YS
I have
- OEM Front swaybar
Thank you kindly
I have
- OEM Front swaybar
Thank you kindly
It was:
Neuspeed Upper Front, Cusco Upper Rear, Spoon Lower Rear bars
RSX rear sway, Stock front sway
Stock springs and shocks at factory alignment settings
17" OZ Superleggeras with 215/45/17 AVS ES100s
It will be:
RSX rear sway, Stock 2003 front sway (13mm)
JIC FLT A2s, 500 lb front, 560 lb rear springs with some extra camber in the front
15" Esses Speedmasters w/ either Azenis or Kumho MX tires
Last years setup worked pretty well, but there was plenty more to be had from the car.
Originally posted by Dr5D
sooo wait... if I take the bar off my EX then it will have more oversteer, and no bad effects???
Autocross Junky
I ran with out the front bar on my 01 EX for a month, it was fun... basically throttle lift oversteer on demand, great for Mid and slow speed corners. Vurtually no understeer. but you need to take extra care not to upset the car when taking high speed turns, or the rear end would want to come around on you. not a problem if you know how to deal with it, but it can be dangerous for the inexperianced.
when I went to the nationals last weekend, I poped in an 03s front bar (16mm), made the car understeer a little, but with the rain we got at the event it was VERY controlable and stable. it actually supprised me as to how stable it was in the rain.
Autocross Junky
Yup, on the coupe the 01-02 had a 25.4 mm front bar, and in 03 they droped it down to a 16mm......
The sedan.... 01 it had a 25.4, in 02 it had a 22mm and in 03 it got the 16mm... Go figure.
sorry for my suspension stupidity...
is bigger better then? let me rephrase - does a smaller one give you more oversteer? This is interesting stuff, Im trying to decide if I should get a bar from an 03
Autocross Junky
so, wait wait.
so, wait wait.
Bigger is not nessisarily better, nor is smaller. what you are looking to do with the different size bars is create balance by adjusting whats called the Roll Couple Distribution. By altering the roll resistance on the front or back of the car you influence its handling chariteristics. The basics go like this, If you increace the roll resistance on the front of the car (Increasing Spring rates or going with a larger front anti-roll bar) then you will increase understeer or decrease Oversteer. The opposite happens if you decrease the front roll resistance.
So, if you get the smaller bar the car will understeer less and possibly oversteer in some circumstances.
if you want to learn more check this out
Autocross Junky
I wouldnt know, Ive never ran like that, but Im sure you will get rid of alot of understeer, but that means that the car will want to oversteer in some higher speed situations.
I say throw the bar on there, most drivers don't want to have to worry about their cas *** sliding out in the middle of a turn and most don't know how to deal with it, so toss the bar on there and drive around with it for a while.
Autocross Junky
Originally posted by 82801BA
Then what will the difference if I swap 19mm RSX-S bar for the rear while keeping the 15mm 03 EX bar in the front!? Any potential danger?
as far as the prelude haveing almost matching bars Front and rear, that doesnt really mean much other then Honda probably has Light springs on the Prelude.
Post Whore General
I've noticed that stock my 03 EX handles better than my old 01 EX did stock. The smaller bar up front helps balance things out more. I'm hoping to upgrade the reaer to the RSX sway bar soon.
Xuhme
21
Aug 7, 2023 03:40 PM
oneheadlight
Apr 29, 2015 11:30 PM
smmahan
Apr 15, 2015 08:17 PM
GH04si
Apr 15, 2015 08:13 PM
a weire thing but it's true....
