need help putting on a str cam gear
Old Jan 7, 2004
2003hondacivic's Avatar
2003hondacivic should not be trusted2003hondacivic should not be trusted2003hondacivic should not be trusted
Exclamation need help putting on a str cam gear
i just got a str cam gear and need some help finding the adjustment for the timeing belt i have looked and looked but no adjustment
Old Jan 7, 2004
IDQcivic's Avatar
IDQcivic should not be trusted
not sure there is an adjustment, I put on my AEM cam gear my self which should be the same procedure, just take the valve cover off, remove the old gear, and put the new gear on and then slip the belt on to the new gear, just make sure you line the belt up to the SAME tooth it was on the old gear, I made a mark on the belt and the old gear, then transfered that mark to the new gear so I knew exactly where it should be, its gunna tough pulling the belt on, just put alittle *** in to it and it should work.... later....
Old Jan 7, 2004
so there is no adjustment on the 7th gen
so all you have to do is slip the belt back on right
Old Jan 7, 2004
mclean987's Avatar
mclean987 is an unknown quantity at this point
Re: need help putting on a str cam gear
hey where did you buy the str cam gear ?
Old Jan 7, 2004
yeah a have the str cam gear trying to fine better way to put it on
Old Jan 7, 2004
this is the cam gear
Name:	str cam gear for civic.bmp
Old Jan 9, 2004
the str gear thay told me that will work for your cars was for a 96 to 01 6th gen
but it will not any one know of any more gears for your car (not aem)
cukaracha
Jun 7, 2015 03:32 PM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
jackshepardjr
May 24, 2015 09:53 PM
thesushiboy
Apr 12, 2015 07:40 PM
CivicPunker17
Nov 21, 2001 06:14 PM
