Car shakes when i hit the pedal
Old Jan 7, 2004
Splicer's Avatar
Splicer is an unknown quantity at this point
Hey guys. My car is shaking whenever I'm accelerating. I notice the more I push the pedal, the more it shakes, but once I hit 3,000rpm, it seems fine again, regardless of the gear I'm in. The car has 50k on it. I dont think its plugs, I put bosch plats in 30k ago. Tried Dry gas, Tried a full fuel/injector cleaner that the guy at Pep Boys recommended. Some people I've talked to say it might be the fuel filter, some are saying it could be the throttle sensor. I'm not really sure what to do. Please Help!
Old Jan 7, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Try the plugs anyway, even if you just put in a cheap set. I have had the odd Bosch plug mess up on me, even new. It's a headscratcher, but it happened. BTW, that was specifically with Bosch Platinums. I think the center electrode broke inside.
Old Jan 9, 2004
Splicer's Avatar
hey, i just read that post now, but just on my own hunch i did go ahead and replace the plugs. that fixed it! after 30k, my bosch plats went bye bye :-( well, i got new ones in now. thanks again!
Old Jan 9, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
you may have over-torqued the plugs. Like Timman said, the center electrode broke inside.
Old Jan 9, 2004
NoFriends's Avatar
I like ruining your threads.
good thing you found the problem, Ive had similar problems with an older toyota that turned out to be a bad o2 sensor.
Old Jan 10, 2004
tinman's Avatar
Guys, (and Gals) Bosh platinums have a certain failure rate. If you put in a brand new set, and the engine shakes even a week later, check the plugs right where the tiny center electrode is. It will most likely be missing. I like Bosch plugs, when they work right. But sometimes it takes 2 tries to get a good set that isn't flawed. Overtightening won't crack the electrode, only strip the cylinder head.
Old Jan 11, 2004
Splicer's Avatar
hey guys. the problem is acting up again. looks like its a short in the spark plug wires. just a coincidence that when i put the new plugs in, it must have temporarily fixed the connection. anyone know a good place i can pick up a nice set of replacement wires and coils?
Old Jan 11, 2004
Our cars don't use wires. It's a direct ignition system with coils. There are aftermarket coils, but they are worse than stock. Oh and those bosch plugs suck in our cars.
Old Jan 12, 2004
Splicer's Avatar
i know our cars have direct coils, but if you read my post, there's a short somewhere. i understand that the coils are right on the plugs, but there is still wires that connect to the coils. if i move the wires around and push down on the coils my car usually runs fine till somethin shifts and loosens up again. i dont neccessarily want anything after market, because you really cant get any better than direct coil. i just want to pick up a set of replacement coils and wires like i said, and i dont know where to go. id rather not get raped by a dealer. thanks!
Old Jan 12, 2004
Check out hondaautomotiveparts.com for prices a little less than most dealers.
http://www.hondaautomotiveparts.com/...catdisplay.jsp
Old Jan 13, 2004
Splicer's Avatar
i couldn't seem to find the coils/wires on that site....
Old Jan 15, 2004
odie's Avatar
odie is an unknown quantity at this point
try www.h-parts.com (or is it www.hparts.com)
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Tedverseti
Apr 23, 2020 01:45 PM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
colombianDXcivic
Nov 8, 2001 05:26 PM
TaiChi
Canada West
Nov 8, 2001 01:21 AM
