look at high flow cat !
Escaped Convict
looks like it'll fit our car. i think. the downpipe seems a bit longer.. I mean before the curve...
and er.. looks like its most likely a straight pipe than an actual cat convertor.
high flow cats usually don't do much at all. It is usually just a straight pipe with not much catalyst inside. That looks more like a resonator to me than a converter.
i have been told by a bunch of ppl that high flow cats are pointless, the gov't regulates how much stuff is inside a cat, so unless u makt urself, its a waste of money to buy one. the only thing i see good in it is if its a wider pipe size.
a high flow cat will allow gases to travel through it faster, where you can gain a few hp. You will lose some torque because you will be losing backpressure. if you can do it, straight pipes will provide the most hp, but you usually can't get away with that unless you have a pure race car.
If you live in states with poor emission controls and no state inspections than just run that or even better, a piece of straight pipe. Here in Florida they have no laws at all i think regulating emissions, compared to NY where you need to have inspections and emissions testing.
Originally posted by Samari
will that fit with an aftermartket header, say a DC Sports ceramic 4-1 header?
Racing converters I believe do have less, which is why they say "off-road use only" on them - because the government can't regulate off-road vehicles.
Wondering the same ^^, i belive the megan and top speed are the exact same downpipes.
I will either be getting one of these downpipes or a magnaflow converter that has to be welded on
Look at this one http://cgi.ebay.com/ebaymotors/ws/eB...tem=2451296883
I just bought this , http://cgi.ebay.com/ebaymotors/ws/eB...tem=2451455740
car wont rev over 7500
i have a d15b block with d16y8 head and i wired up my vtec today it comes in at 5200, the check engine light is no longer on only problem is that the limiter is coming in a 7500 and ecu is programmed to 10,000rpms, anyway it works on my friends d16z6 very good and revs all the way to 9500, i tried another ecu and its the same thing so its something with the engine can someone help me with this please ? thanks i haev i/h/e zex cam, fuel pressure regulator
i have a zex cam and valve springs and retainors
HAPPY NEW YEAR
HAPPY NEW YEAR
i aslo was looking at the mid pipe on ebay, will i still pass inspection with it? I live in NJ...
also you guys remember the post about our civics making a crazy ratteling/gringding noise when it rains only.... you think a new cat midpipe will resolve that issue? (i know its a bit off th etopic but all you got to do is say either yes or a no) thanks
jzhartman
22
Jul 23, 2015 10:42 PM
cizsak
Jul 21, 2015 03:39 PM
