Air Intake Owners! Ppl With Bad Gas Mileage..cel Wont Turn Off?check This!
Old Dec 18, 2003
2k3HonCivicEX's Avatar
2k3HonCivicEX is an unknown quantity at this point
Exclamation Air Intake Owners! Ppl With Bad Gas Mileage..cel Wont Turn Off?check This!
Well, i could not get my check engine light to turn off. I kept resetting ECU and it would turn back on. I also was getting like 17 miles to the gallon. today i took my car to the dealerthis, and they ran 2 hours of diagnostic tests and a fuel pressure test or somethin... The found the the hose that you replace when installing an aftermarket intake... not recycled air hose... the vaccum hose (not necessary to change but Injen and AEM give them to you cause stock isnt long enough.. Well the stock clamps i got off of the stock hose didnt clamp hard enogh cause this hose was thicker, and so the guy got his spool of vaccum hose, reeled it out and got some clamps and through it on. The hose wasnt tight enough so it wasnt returning air properly.... Anyway check this out if you have my symptoms or remember changing the hose.
Old Dec 18, 2003
cdmx's Avatar
Exactly which light?
Old Dec 18, 2003
Samari's Avatar
was it the maintenace light or the malfunction indicator (engine check)? I really dont think that would be a problem
Old Dec 18, 2003
Connie's Avatar
yeah, I can't see the ECU detecting that......unless your intake was totally blocked or something
Old Dec 18, 2003
it was the little orange light with the symbol, not maintanence required
Old Dec 18, 2003
prawdigy's Avatar
prawdigy is an unknown quantity at this point
yea.. my friend's integra had a check engine light problem too and my other friend sed that it usually comes on wen theres an air leak.. and sure enough there was.
Old Dec 19, 2003
Joey_Zazza's Avatar
Joey_Zazza is an unknown quantity at this point
yo
I have a 2k3 ex as well. And I installed the AEM CAI. I got the check engine light one. I bought one of those diagnosis testers majiggy's,lol whatever u call it, that hooks up to ur ecu and tells you what is wrong and allows u to reset the error code. It was saying there was something wrong with the temp sensor, which goes into the air intake, so either i have a leak, or my sensor is bad, which it shouldnt be. I'll try the hoses cause the one they send is different than the stock one. I'll try it out and post back. I'll get the exact error message it is giving me and post that as well.
Old Dec 19, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
soundlike another good reason for people to get the K & N FIPK II !!!!!
Old Dec 19, 2003
chriscivic's Avatar
chriscivic is an unknown quantity at this point
Are you talking about the hose from the intake pipe to the top of the valve cover?
Old Dec 20, 2003
Joey_Zazza's Avatar
Talking moo
yes
Old Dec 20, 2003
Drkstalkerr's Avatar
Drkstalkerr is an unknown quantity at this point
i had the engine light problem when i installed my cai, but after driving around for an hour or so it went away. . . almost like it just needed to adjust or something. oh well. haven't seen it since
Old Dec 20, 2003
01civicboi's Avatar
01civicboi is an unknown quantity at this point
what hose? The only 2 things that are connected to the intake are the O2 sensor and the breather tube. Would not having a breather tube shouldn't cause a CEL?
Old Dec 20, 2003
FattyMcJ's Avatar
Addicted to the Twisties!
Don't mean to be rude...but...
HELLO McFLY!!!!!!
Did you not read the DIY!?!?!?!?
Taken from the Installing AEM CAI DIY
The Final Step: Remove protective tape on AEM logo!
Also, you may want to reset your Fuel Injection ECU. If you don't your car will still eventually learn how to deal with the new mass amounts of air. This just makes the process a little faster.
Thanks to 2k1civic.com member knight who posted this a long *** time ago.
To do this:
A) Open the fuse box in your engine compartment and look on the diagram for the F.I. ECU (7.5 amp fuse)
B) Pull the fuse out and wait 10 minutes or longer.
C) Put the fuse back in.
D) VERY IMPORTANT - Start the car, and DO NOT touch the gas peddle!!!
E) Let the car idle for about 10 minutes, DO NOT toch the GAS!!!
F) Turn off car.
G) Turn on car, and turn back off.
H) Turn back on, and make some noise!!!
Old Dec 21, 2003
slowvic's Avatar
slowvic is an unknown quantity at this point
The silicone vaccum hoses that come with alot of intakes are shitty. They softer that rubber vaccum hoses. I have seen some that have collapsed.
Old Dec 21, 2003
Joey_Zazza's Avatar
poopies
I tried the whole take the fuse out etc, just now. I waited bout 15 mins. I started the car, let it idle for 10 mins or so, did not touch the gas. Then i did the start, turn off ,start ****, and now the Maintance Required light is blinking each time i start the car, it turns off, but now whenever I start it, it blinks for like 10 secs, and the check engine light is still on. I disconnected the battery and am lettin it sit for a few mins and will turn it back on and see if that resest the computer.
Anyone have a solution to gettin rid of the maintance required light?
Old Dec 21, 2003
Joey_Zazza's Avatar
Angry boo
ok, battery trick did not work. If anyone can help, please post, id appreciate it.
Old Dec 21, 2003
mclean987's Avatar
mclean987 is an unknown quantity at this point
Re: poopies
hold down the button to reset mileage for 5 seconds with car off but ignition in the engine on mode
Old Dec 21, 2003
Joey_Zazza's Avatar
thanx
THANX, ill give it a try before i go to work tonight.
Old Dec 21, 2003
b18c1boy's Avatar
b18c1boy is an unknown quantity at this point
read your owners manual. it tells you how to reset it.
Old Dec 23, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
that hose is the PCV vent, or positive crankcase vent... I doubt that would casuse the CEL to come on, because a lot of people take that hose off and put a small breather filter on there to vent the gases, all that hose is for is to vent gases out back into the intake. Its parts of emissions so harmful gases arent let directly into the air.
ORskier
May 7, 2015 04:54 PM
carid
Apr 30, 2015 07:00 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Lightman
Nov 10, 2001 06:44 PM
Hobby2K
Nov 9, 2001 04:08 PM
