Note To All Regarding Gauge Calibrating!
Old Dec 17, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
As some of you have seen, I posted that in an attempt to install my reverse indiglo gauge faces, I messed up all the needles and they went wacko when the car turned on.
Well guess what...
No need to:
Go to the Honda Dealer...
or
Send it into Honda under warranty...
or
Buy a new cluster and fiddle with the milage, etc...
What I did?
1) Turn on car (All needles will move to their "false" position)
Take a look at the needles (again, w/ the car powered on)
Temp needle all the way up? Carefully pull out needle and re-place in its correct position (slightly below halfway for a fully warmed up engine)
same goes for the other needles... the RPM and MPH should be sitting at dead bottom. Pull 'em off and set them in their correct (dead bottom) position)
Just hope you remember how much gas you had (for the gas needle)
Everything is perfect now! No need to spend $500!
Old Dec 17, 2003
Green Civic's Avatar
It works fine now? Well, glad to see you not spend 500 dollars. You can go to the gas station and fill to full and you wont have to remember where the gas gauge was at.
Old Dec 17, 2003
cryption's Avatar
2003 Nissan Frontier
my needles just stick .. guess because its too tall or i pushd it down kinda sideways or somethin ... I'll fix it one of these days maybe
Old Dec 17, 2003
guamcivic2k1's Avatar
YoUnG N SuXsExFul
thanks for the info..gonan put gauges on too
Old Dec 17, 2003
MangoEX's Avatar
Just Be
As far as the needles sticking, thats an easy remedy. Notice how our civics' needles have a little edge sticking out ( in parallel with the needle itself) just gotta file that down because if it slightly rubs against the new gauge faces (which causes the sticking), it can't move.
Old Dec 17, 2003
cryption's Avatar
ty sir! im gonna try it
hewey23
Suspension
Sep 4, 2022 07:58 AM
tylerginevan
Apr 27, 2015 12:29 PM
Dorval Andre
Apr 20, 2015 05:34 PM
GTekCiViC
Jan 26, 2002 08:25 AM
GTekCiViC
Jan 25, 2002 04:26 PM
