???02 Acura RSX Camber Kit Compatible With 2k1civics???
Balut Eating Champ
Just recieved my RevoTechnica camber kit just this afternoon and I noticed that the box for the front camber kit says "02 RSX" and the rear camber kit box says "02 RSX/ 01 Honda Civic"??? 02 RSX camber kit compatible with 2k1Civic???
Any RevoTechnica camber kit owners???, need your help please verify!!!, so I can intall mine ASAP, but I don't wanna take everything off and later finds out that the item they sent me is not the right part, AGAIN
.... Thanks! Happy Holidays 7thGen Fans
I will give you heads up on the RSX/Civic parts. The RSX, Civic Si, and the 7thgen Civic ALL share the same chassis. Therefore, alot of suspension parts can be used in all three, some may need some modification, but most will fit. So yes, that camber kit fits your car. It seems you are new and you wanted to make sure, but please search around and read the suspension forum for more information. It is all here.
The Standard One
only difference is the front bolt... it seems as if even rsx's has two different part numbers for the front bolt. i guess acura at one time or another decided to use smaller/bigger bolts on some cars...
Balut Eating Champ
Yup!!! just found that out today! since i didn't touch the wheels for bout a year it was a pain in the *** to take the lug nuts off, and the bolt was stripping, so i spent bout 45 mins taking those suckers off, and FINALLY after I got em all unscrewed my back hurt so bad thought to myself, "I should've bought the god damn, impact wrench set and the compressor for 130 bucks". And yes it happened to me again, got everything taken off and BAM!!! wrong F@#$ing part, but the rear's good to go...... and now I have to get those bastards who sent me these stupid bolts that won't fit!!!
Search and Learn
Hutch1051
Sep 29, 2015 09:20 AM
