???02 Acura RSX Camber Kit Compatible With 2k1civics???
Old Dec 17, 2003
pnoyster2k1cvic's Avatar
Balut Eating Champ
Question ???02 Acura RSX Camber Kit Compatible With 2k1civics???
Just recieved my RevoTechnica camber kit just this afternoon and I noticed that the box for the front camber kit says "02 RSX" and the rear camber kit box says "02 RSX/ 01 Honda Civic"??? 02 RSX camber kit compatible with 2k1Civic??? Any RevoTechnica camber kit owners???, need your help please verify!!!, so I can intall mine ASAP, but I don't wanna take everything off and later finds out that the item they sent me is not the right part, AGAIN .... Thanks! Happy Holidays 7thGen Fans
Old Dec 17, 2003
robbclark1's Avatar
Retired suspension supermod.
I will give you heads up on the RSX/Civic parts. The RSX, Civic Si, and the 7thgen Civic ALL share the same chassis. Therefore, alot of suspension parts can be used in all three, some may need some modification, but most will fit. So yes, that camber kit fits your car. It seems you are new and you wanted to make sure, but please search around and read the suspension forum for more information. It is all here.
Old Dec 17, 2003
VNlilMAN's Avatar
The Standard One
only difference is the front bolt... it seems as if even rsx's has two different part numbers for the front bolt. i guess acura at one time or another decided to use smaller/bigger bolts on some cars...
Old Dec 17, 2003
Balut Eating Champ
Yup!!! just found that out today! since i didn't touch the wheels for bout a year it was a pain in the *** to take the lug nuts off, and the bolt was stripping, so i spent bout 45 mins taking those suckers off, and FINALLY after I got em all unscrewed my back hurt so bad thought to myself, "I should've bought the god damn, impact wrench set and the compressor for 130 bucks". And yes it happened to me again, got everything taken off and BAM!!! wrong F@#$ing part, but the rear's good to go...... and now I have to get those bastards who sent me these stupid bolts that won't fit!!!
Old Dec 17, 2003
hondaciv01's Avatar
hondaciv01 is an unknown quantity at this point
almost positive it is. i know my skunk2 coilover set up can go in the acura rsx, and almost all the suspension parts i can buy from major companies can go into the rsx
Old Dec 17, 2003
civicvtec1ps's Avatar
Search and Learn
Yea you need 14mm bolts instead 16mm.
UltraHDGames
Jun 8, 2016 05:16 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
