what do you need when lowering car?
Old Dec 7, 2003
fastcivic03's Avatar
fastcivic03 should not be trusted
Hi I recently lowered my car wit goldline springs, and I like them very much. I've heard you need to add other things for your suspension such as struts, camber kits etc. I plan on later gettin new bigger tires and rims, what do I need to get? This question has probably been answered millions of times, but I looked at the recent 50 posts under this topic and couldnt find the answer. Someone please help, what do I need thank you.
Old Dec 7, 2003
MORG655's Avatar
MORG655 is on a distinguished road
Since you don't have adjustable ride height with your springs, you don't NEED a camber kit. It'd be nice to have if you camber wanders out of adjustment. I assume you got your car aligned once you put the springs in. You don't NEED struts either. Again, they will make things mo better. w0rd
Old Dec 7, 2003
4bangin's Avatar
dude, look at the top of the suspension page...the suspension faq and suspension tuning 101 threads. it will tell u EVERYTHING.
Old Dec 7, 2003
Yes I've read that all it states is camber kit, what about the struts, sway bars etc. ?? what do you guys think?
Old Dec 7, 2003
Mr.Modify's Avatar
all that has been discussed before man!
you don't need to replace struts LMAO if you put springs on most likely the shocks though
and sway bars you don't need when you drop it neither! seriously though search!
here's what i recommend:
1) if you use springs get a camber kit/new shocks/ alignment
2) if you use sleeved coilovers get new shocks/camber kit/alignment
3) if you use true coilovers umm well alignment!
Old Dec 7, 2003
tfnaaf's Avatar
BLDNPSI Mod
Always Always Always Always Always Check alignment after ride height change or suspension work. And if its out of spec BUY THE KIT!
Old Dec 7, 2003
robbclark1's Avatar
Retired suspension supermod.
please search. Read the FAQ and Suspension Tuning 101 by Zzyzx. Just read around the board. We are not repeating over and over again what has been said a million times. If you know nothing about lowering your car and you threw a set of goldlines on there, then you should have researched more. Please research before you slap another part on your suspension without knowing what it does.
Tedverseti
Apr 23, 2020 01:45 PM
bsmiley
Apr 27, 2015 01:27 PM
2Hondaz
Nov 8, 2001 11:00 AM
Zillaaa
Nov 2, 2001 05:11 PM
ImmortalEX
Oct 31, 2001 10:00 PM
