Lower Bottom Brace DIY
Old Dec 4, 2003
Texas Rice's Avatar
Texas Rice is an unknown quantity at this point
Can anyone help me out? The one I bought does not have instructions, I want to do it right. I couldn't find one via search. Thanks
TX rice
Old Dec 4, 2003
Zzyzx's Avatar
Autocross Junky
whats a lower bottom brace???
Front of the car, Rear of the car??? Need more info.
Old Dec 4, 2003
Texas Rice's Avatar
I'd assume is goes on the rear to prevent frame benting when turning, I see where I bolt it on but I wanted to make sure when if I loosen those bolts my axle doesn't fall off or somthing hehe.
Old Dec 4, 2003
Zzyzx's Avatar
Autocross Junky
So your talking about a rear lower Tie bar...
Some thing that looks like this
I'm pretty sure some one did a DIY for it, seach for Rear lower Tie bar.
Old Dec 4, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
the rear sway bar DIY includes instructions for this
Old Dec 4, 2003
jwalker87's Avatar
Bodacious Member
Old Dec 4, 2003
jwalker87's Avatar
Bodacious Member
sorry for double post
Old Dec 4, 2003
Texas Rice's Avatar
Its this..
Old Dec 4, 2003
7thGenerasianCivic's Avatar
Yes...that will have to be the lower tie bar.
Old Dec 4, 2003
Texas Rice's Avatar
Ok, tie bar, still no DIY on the site for it, can anyone help me? AIM: nonamesleft89
Old Dec 4, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
have fun with it not easy to do i had a lil bita trouble with my progresssway bar grey has a DIY on it
Old Dec 4, 2003
jwalker87's Avatar
Bodacious Member
like i said: go to the rear sway bar DIY (i think by grey). If you read that it also tells you how to install the rear lower strut bar!
Old Dec 4, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Undo the LCA bolt... As you undo it, get a screwdriver or something and stick it in the hole from the back side. That way the LCA doesn't fall out of the suspension mount. Do one side, put the bar endplate on and screw the bolt back in. You'll probably have to manuver the LCA around to get the bushing to line up straight. Then repeat for the other side.
Obviously, do this with the car Jacked up.
Note A: There is no rear "axle", the car is Front wheel drive
Note B: That bar doesn't do anything unless you've got a sway bar upgrade too.
Old Dec 4, 2003
opto_isolator's Avatar
Actually its not THAT difficult - yes it does take some gusto (and the jack can help too), but give it a little time and you'd be good.
Old Dec 4, 2003
jwalker87's Avatar
Bodacious Member
the problem is just lining up the holes
Old Dec 4, 2003
Texas Rice's Avatar
I got it on, hurray! But in turn, I used a ghetto fab way. I had 4 jacks, 2 holding up my car and two hold up my LCAs.. Still had to use a strewdriver to straighten the hole out to re-fit the bolt in, wish I would have seen boilermaker1's way first. Away, thank you for listening to newbieness if there is such a word.
TX Rice
Old Dec 4, 2003
Congrats man - its always good when things work out.....now go have a beer!
Old Dec 5, 2003
acidbaby's Avatar
The Beez Kneez
:beer:
naokigoffi
Aug 30, 2015 06:19 PM
honda.lioness
Aug 21, 2015 02:36 PM
WaryDriver
Aug 8, 2015 05:08 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
Jul 12, 2015 11:54 AM
