front camber kit
Old Dec 2, 2003
guamcivic2k1's Avatar
YoUnG N SuXsExFul
front camber kit
when do you use the front camber kit? i heard that u dont really need it, unless u drop it alot..
Old Dec 2, 2003
djmota's Avatar
you heard correct.
I wouldn't worry unless you are going 2" or more.
Old Dec 2, 2003
YoUnG N SuXsExFul
i also heard that goldlines settel at 2, is this tru? if it is..i might need to get a full camber kit
Old Dec 2, 2003
djmota's Avatar
I am not sure what goldlines settle to but i think you should be all right without.... but hey, they are only 35 bux or so for the pair...
Old Dec 2, 2003
CivicHX01's Avatar
$35 is kinda a lot... you can find SPC front camber kit for around $20-$25 if you look hard enough
but yea, because the way the front suspension is designed, you won't get that much camber change when the height is changed compared to older model civics/integras
however, the rear camber goes negative pretty drastically as you lower more..
Old Dec 2, 2003
YoUnG N SuXsExFul
what's a good price for th rear camber kit?
Old Dec 2, 2003
civicvtec1ps's Avatar
Search and Learn
$100-125
Old Dec 2, 2003
YoUnG N SuXsExFul
where? 100-125? i keep seeing 130-140
Old Dec 2, 2003
Search and Learn
http://spc.danscreations.com/
Old Dec 2, 2003
C0rnfl4k3's Avatar
C0rnfl4k3 is an unknown quantity at this point
Originally posted by djmota
you heard correct.
Really.... I've got Eibach Sportlines with roughly a 1.5" - 1.75" drop in the front and the insides of my front tires have gone almost completely bald after 15,000 miles.
My suggestion if your gonna drop your ride go all the way and get a camber kit for the WHOLE car. If you look hard enough you can find some REALLY good deals, found the whole Ingalls kit on Ebay for $115 shipped.
Old Dec 2, 2003
YoUnG N SuXsExFul
ingalls kit for 115 shipped..wow..lemme look for some
Old Dec 3, 2003
djmota's Avatar
did you get an alignment after the drop ?
Old Dec 4, 2003
C0rnfl4k3's Avatar
^ yes I did.
Old Dec 4, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
my advice is get the camber kit all around... I had the pro kit before which is only 1" and had no camber kit, well it made my tires so bald on the insides I almost had a blow out... Just get the kit, its not expensive and it will save your tires in the long run.... don't go half *** with your car, if you're gunna do it, do it right the first time....
Old Dec 6, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
<<<<TEIN Type Flex has upper pillowball mount with camber plate
Old Dec 6, 2003
robbclark1's Avatar
Retired suspension supermod.
so does JIC FLTA-2's
Old Dec 6, 2003
yep its a pretty good setup just need to get the rear camber kit on and ill be set
Old Dec 6, 2003
tfnaaf's Avatar
BLDNPSI Mod
Anyone who suggest to NOT have the alignment checked Just some background on myself ive been in the automotive field for over 15 years, 9 of which was doing mainly wheel alignments, suspension, and brake work. Some shops will even give free alignment checks! I did Eibachs on my civic and it took the Camber on one wheel to the max negative camber and the other side to just beyond max negative camber on the front and about the same on the rear ( damn stereo equipment ). Typically thou your Toe setting is what will be more critical of a setting and can cause much more rapid tire wear. But if you spend the kind of $$$$$ i did on tires camber kit is well worth it. And lets not forget to rotate them tires
Old Dec 6, 2003
Mr.Modify's Avatar
way to copy and paste from the other thread
Makeice3498
Jul 2, 2015 11:13 AM
ernhole1
Dec 6, 2001 12:05 PM
speed werx
Nov 27, 2001 08:52 AM
JeffSpeed21
Nov 4, 2001 10:32 PM
ImmortalEX
Oct 31, 2001 10:00 PM
