front camber kit
I am not sure what goldlines settle to but i think you should be all right without.... but hey, they are only 35 bux or so for the pair...
$35 is kinda a lot... you can find SPC front camber kit for around $20-$25 if you look hard enough
but yea, because the way the front suspension is designed, you won't get that much camber change when the height is changed compared to older model civics/integras
however, the rear camber goes negative pretty drastically as you lower more..
Search and Learn
Originally posted by guamcivic2k1
where? 100-125? i keep seeing 130-140
Originally posted by djmota
you heard correct.
I wouldn't worry unless you are going 2" or more.
you heard correct.
My suggestion if your gonna drop your ride go all the way and get a camber kit for the WHOLE car. If you look hard enough you can find some REALLY good deals, found the whole Ingalls kit on Ebay for $115 shipped.
Originally posted by C0rnfl4k3
Really.... I've got Eibach Sportlines with roughly a 1.5" - 1.75" drop in the front and the insides of my front tires have gone almost completely bald after 15,000 miles.
my advice is get the camber kit all around... I had the pro kit before which is only 1" and had no camber kit, well it made my tires so bald on the insides I almost had a blow out... Just get the kit, its not expensive and it will save your tires in the long run.... don't go half *** with your car, if you're gunna do it, do it right the first time....
Anyone who suggest to NOT have the alignment checked
Just some background on myself ive been in the automotive field for over 15 years, 9 of which was doing mainly wheel alignments, suspension, and brake work. Some shops will even give free alignment checks! I did Eibachs on my civic and it took the Camber on one wheel to the max negative camber and the other side to just beyond max negative camber on the front and about the same on the rear ( damn stereo equipment ). Typically thou your Toe setting is what will be more critical of a setting and can cause much more rapid tire wear. But if you spend the kind of $$$$$ i did on tires camber kit is well worth it. And lets not forget to rotate them tires
way to copy and paste from the other thread
