greasable energy bushings
Old Nov 26, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
ok, so energy suspension has greasable bushings... now what is the difference between the greasable and non greasable
what kind of grease do u use
how do you grease the bushings
im trying to do research before i buy
Old Nov 26, 2003
robbclark1's Avatar
Retired suspension supermod.
They give you packets of grease with them. the bushings are grooved on the inside to allow grease to sit in there. I put my sway bar bushings on awhile ago and they squeek a little. When I put my control arm bushings on, I am prepared for mad squeeking, but if you grease them well enough they shouldn't squeek. However, you will need to grease them througout their time on the car. Now I am not sure how that is done, but I think it involves some sort of greasing gun/pump. From what I understand, I beleive the greasable ones are better.
Old Nov 26, 2003
CapYoda's Avatar
Escaped Convict
everything really is greasable... its just they make the grooves withing the bushing so the grease wont come out when installed.
they also have a hole in the bushing and the bracket, so that greasing it will be easier.
as for grease... any type of rubber/metal grease that you can find should be okay... although there's different types in that they can withstand different temperature and driving condition... etc.
I dont even remember what I used... just this bottle i have that i apply over the bushings now and then.. havne't heard any squeeks yet so until I do I wont reapply.
Old Nov 27, 2003
Grey's Avatar
DIY King
The greasable ones have a little nipple and grooves on the inside that hold grease. The non grease-able ones have little grooves on the inside as well. I guess they should really call them "re-greasable". Anyway, whatever... They're good. I have them. I also have a grease gun. I grease them up from time to time. Actually... Good idea. I'll do that today. I simply place the grease gun over the nipple and squeeze the trigger until grease starts to flow out from the seams. Works.
ThatGuy913
Sep 28, 2015 05:35 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
czarlun
Sep 14, 2015 08:16 PM
