RSX suspension on our cars?
Old Nov 19, 2003
Hwoody77's Avatar
Hwoody77 can only hope to improve
Hey, I am looking around for coilovers..I read that RSX suspension fits(Tein FLEX, Buddy Club) My questions is what modification(if any) is required to install them?
Old Nov 19, 2003
robbclark1's Avatar
Retired suspension supermod.
you will need new tie rod ends and some new bolts. The EP ones should fit right in so try to get those instead.
Old Nov 19, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
I have the EP3R TEIN type flex on my coupe u will need to cut a hole in the webbing of the hood in two spots to make them fit but other than that they fit with no hassle
Old Nov 19, 2003
HondaLuver's Avatar
Its a celebration bitches!
do you have the EDFC?????? also...
what ever you get should be for a ep3.//.
Old Nov 19, 2003
Vinh's Avatar
what is em, ep3, and dc5?
Old Nov 19, 2003
Zzyzx's Avatar
Autocross Junky
its the chassis code
em2 = civic coupe
EP3 = civic hatch back
DC5 = RSX
Old Nov 19, 2003
4bangin's Avatar
im trying to get a hold of a set of the KW2 coilovers for the ep3. i heard they are hard to find though. anyone know any more about them?
Old Nov 19, 2003
Vinh's Avatar
em2 = civic coupe
DC5 = RSX
sorry.....i was trying to be sarcastic
but really....i really knew that
Old Nov 20, 2003
Zzyzx's Avatar
Autocross Junky
sarcasim doesn't translate well in text......
Old Nov 20, 2003
civicvtec1ps's Avatar
Search and Learn
http://tornactive.com/pd_kw_coilover...ion_v2_for.cfm
KW Suspensions North America offers one of the largest application ranges of Coilover suspension systems in the world. The innovative, integrated KW solutions allow you to lower your vehicle within a safety tested TÜV-approved* height range. This means sporty driving and stylish appearance while maintaining ride comfort.
KW Coilover systems are a combination of lowering springs and specially tuned shortened shock absorbers that have been coupled with engineered threaded strut housings that allow you to lower your vehicle within a specified range using the adjustable aluminum spring perches.
All KW Coilover systems are constructed using the new stainless steel INOX-line strut housings that provide the ultimate in corrosion resistance, guaranteeing functionality for the life of the vehicle. KW Coilover Suspension Systems are available in three damping variants to suit your driving needs.
Old Nov 20, 2003
Hwoody77's Avatar
Well, my friend is sellin me his RSX Tein FLEX Suspension for cheap, and I want to mod it to fit on my car...
Does anyone know the thread where RSX suspension was placed on our cars?
Does anyone know EXACTLY what is required?
I have searched and found nothing...
Old Nov 20, 2003
robbclark1's Avatar
no we don't know exactly because not many people have done it. You might want to talk to Hawk or Hondawerx because they put the 4 wheel disk brakes on so the whole system was transferred over. I know you will need new tie rod ends because the RSX ones are bigger. You will also need larger bolts for the front. Other than that I can't help ya. You might just have to be a guinea pig! haha
Old Nov 20, 2003
i have the flex for the civic type r like i said above.....they are the same as the rsx(dc5) u will need to cut a hole in ur hood but not really big unless u want to use the edfc
i dont have the edfc cause no need for it and wont fit with the spoon strut tower bar it wont mount with the mounts for the bar either nuespeed bar would make it easier to fit if u wanted it
Old Nov 21, 2003
JDMCIVIC's Avatar
JDM WHORE!!!
JDMCIVIC will become famous soon enough
what do you guys think about the Mugen full coils for the EP3. Should those fit with no prob.
Old Nov 21, 2003
robbclark1's Avatar
are they the full coils or the matched shock/spring set?
Old Nov 25, 2003
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
Let said i pick up a set of full setup for a rsx ie: tein or buddy club
I can put this on my 01 civic all i need to change is the tie rods
and new bolts?
correct me if i am wrong?
Old Nov 26, 2003
the coilovers for the si will fit also with no tie rods needed
Old Jan 16, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Let me see if I read this right, the ep3 suspension should bolt right into the em2 chasiss ?
Old Jan 16, 2004
robbclark1's Avatar
yes in most cases it should.
Old Jan 16, 2004
MrWong's Avatar
Bushido
What are the cases where it would not bolt on to the em2 chasis ?
Old Jan 16, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Let me re-word what Rob said... I'm going to make sense of this.
EP3 parts will bolt right in, all the components are the same, I spent months crosschecking parts to make sure of this.
The case where you will have issues is with fixed drop systems. The EP3 springs are longer in the front and shorter in the rear. So whatever the specified drop is, will not be what you get. You'll get a front that sticks up and a rear that sags.
Basically the only thing that can be swapped are the full replacement coilover systems where you can adjust the height, and come with their own shocks.
Basically, JIC Magic and Tein Flex. You need to trim the hood frame for the Teins, but its a minor thing. Other than that, just use the EM/ES parts or you'll end up with a funny looking car. Pretty much everything else but the ultra-high end stuff is made with a normal Civic application anyways.
Old Jan 16, 2004
robbclark1's Avatar
Thanks for the clarification...i was in a rush and didn't have time to go into detail. The reason full coilovers will fit in is because the height is adjustable and there is no dead coils at the bottom. There are weight distrubtion differences in the cars so that is why springs won't swap right in correctly.
Tedverseti
Apr 23, 2020 01:45 PM
oneheadlight
Apr 29, 2015 11:30 PM
GH04si
Apr 15, 2015 08:13 PM
SleepyT
Nov 1, 2001 04:59 AM
