Stripped Header Bolt
Old Nov 16, 2003
02ciVike's Avatar
02ciVike is an unknown quantity at this point
Please someone help me. I have stripped the bolt near the alternator trying to remove the stock header. There is still a little bit of thread left so I might be able to do something about it. If anyone knows any thing I can do or buy that will loosen this bolt please help.
Old Nov 16, 2003
UnOrthodox9546's Avatar
UnOrthodox9546 is an unknown quantity at this point
This same thing happened to me. I still havent gotten it off
Old Nov 16, 2003
centurioncivic's Avatar
centurioncivic is an unknown quantity at this point
were u using a 12 point socket, i did that too without thinking and it stripped a bolt, so i took a 6 point socket to it and it came right off. you can try some wd-40 or antiseize stuff and use a torque wrench, hope this helps.
Old Nov 16, 2003
02ciVike's Avatar
Thats discuraging... So far I have tried Liqiud Wrench (the strongest formula) and I bought some sockets for stripped bolts but they are too large to fit in that small area. I was using a 6 point socket so that won't help. Any one else have this problem? I was thinking about taking it to a a professional mechanic. I there anything that he could do?
Old Nov 16, 2003
Ike's Avatar
Ike
Ike is an unknown quantity at this point
I used wd-40 and got a pair of vise grips.
Old Nov 16, 2003
02ciVike's Avatar
What type of vise grips? How did you get them to fit in that small space? I have tried vise grips but have not had any sucess. Did you use any kind of special technique?
Old Nov 17, 2003
02ciVike's Avatar
Problem resolved. I took the car over to a mechanic while I was at work they heated up the bolt and played with it for about an hour and it finally came loose. Thank God. The Ceramic coated Kamikaze header is great, pulls harder past 4000rpm plus it looks hot.
UltraHDGames
Jun 8, 2016 05:16 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
anubis62
Sep 27, 2015 12:56 AM
