Suspension Questions 101
Old Nov 12, 2003
jaypog's Avatar
jaypog is an unknown quantity at this point
Question Suspension Questions 101
Hi all,
Im not satisfied with the oem suspension of my 01 Civic Sedan. Before I decide to upgrade it, I want to verify some things.
1. Im more interested in comfort, should I be installing softer suspensions? Specifically to eliminate bouncy rear.
2. Softer springs is bigger or smaller in diameter?
3. Can progressive springs answer my needs? or softer struts?
4. Brands of products I should look for?
Any suggestions are welcome.
Many thanks!
Jay
Old Nov 12, 2003
Zzyzx's Avatar
Autocross Junky
1.Softer springs would give you a softer ride, but springs don't elimiate bounce, shocks do.
2. smaller
3. They might
4. B&G? maybe Tein basic (and have them put on a softer spring rate)
the biggest problem I see here is if you want to lower your car. If you go with a soft spring and lower the car, the suspension may bottom out when you go over bumps. other wise, a quality set of shocks on the stock springs may be all that you need. Like a set of Konis set on the softest setting or something allong that line.
Tedverseti
Apr 23, 2020 01:45 PM
edspyhill09
Jun 12, 2016 02:45 PM
oneheadlight
Apr 29, 2015 11:30 PM
viper775
Dec 9, 2001 10:52 PM
