Reset ecu = bad gas mileage
Old Oct 16, 2003
lid6662's Avatar
lid6662 is an unknown quantity at this point
I just reinstalled my cai and i dissconnected the battery while doing it. I have noticed that i hit around 180ish right at half a tank. Normally I am at over 200 220 at half a tank. I also have driven it eaiser than normal just to see what my gas mileage is? Any ideas?
-matt
Old Oct 16, 2003
DaSilviC's Avatar
DaSilviC is an unknown quantity at this point
since u installed your cold air intake, ur taking in more air and thus more fuel needs to be burned off to compensate.........just a hunch
Old Oct 16, 2003
TeLLy's Avatar
Yes, it's an Acura EL
That's one POV and it's true, more air alone does not = more power. More air + more fuel = more power. Theoretically. However, it could also be that the ECU could still be adjusting and you may yet see your milage improve as the ECU re-learns how to map its air/fuel ratio throughout all throttle positions. I dunno, that's just what I think. My milage was crap when I first installed my intake, but now I'm doin about the same as when I was runnin stock. The reduced milage can at this point be attributed to me revving a little more to hear the growl of the intake. I'm such a ricer. Shoot me.
Old Oct 16, 2003
mclean987's Avatar
mclean987 is an unknown quantity at this point
thats mean everything is working ok because the same thing happened to me more air = more fuel = more power, dont you notice car is faster ?
Old Oct 16, 2003
Novaz3's Avatar
Novaz3 is an unknown quantity at this point
no offense but how can the ECU adjust to new air/fuel ratios??? last time i checked you had to tweak the ECU to handle the new air.fuel ratio but i could be wrong
Old Oct 16, 2003
Vinh's Avatar
aem cai = noise not power
Old Oct 16, 2003
alienmeatsack's Avatar
alienmeatsack has a spectacular aura aboutalienmeatsack has a spectacular aura about
from what I understand about the ECU on our cars, it automatically adjusts itself periodically. So if you install a CAI or SRI and don't reset it, it will eventually do it itself.
installing the CAI dropped my mileage, but I dont get huge mileage anyhoo since I tend to lay on it most of the time.
Old Oct 16, 2003
Vinh's Avatar
on the contrary.....driving fast often is good on the
spark plugs and enabling an unnoticeably difference in gas mileage
Old Oct 16, 2003
Vinh is right. I used to drive slow and my plugs fouled at 17K miles. As for gas mileage, you have it easy. I get 24mpg max on a good run. I'm at 200 miles and almost on empty! Don't worry, the ecu will learn on its own. Just remember the intake draws in more air and thus more fuel is needed. Intakes won't show more than 1hp gains on our cars.
Old Oct 16, 2003
Logan3024's Avatar
weird? Check to see if one of your tires in low in air.
Old Oct 16, 2003
03civicdx's Avatar
03civicdx is an unknown quantity at this point
i droped alot of gas mileage when i put my intake on but usually with better filter the engine doesnt have to struggle as much to get that extra power its got a free breathing filter instead of the quiet restrictive stock one. Thus the amount of air/fuel goes up but the energy goes down so after the ecu resets you should come back to normal or possibly even better depending on how you drive. but it shouldnt fluxuate much more then loosing or gaining 20 miles per tank.
Old Oct 16, 2003
I actually lost 2mpg AFTER taking off my SRI and going back to stock. Doesn't seem right, but oh well.
Old Oct 16, 2003
03civicdx's Avatar
no that does sound right, the engine has to struggle for the air and work harder thus taking more gas. although with this crazy computer in our cars with no fuel pressure regulator its just hard to figure out,
Old Oct 17, 2003
lid6662's Avatar
Cool Ya i Am thinking after this tank it will be back to normal. I am at right around 300 miles now and its still got some gas left maybe 50ish miles?
Old Oct 17, 2003
Wanger's Avatar
Wanger is an unknown quantity at this point
that means that SRI's suck and stock gives more power
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
Thees1
Apr 14, 2015 08:23 AM
Jandree22
Jan 4, 2002 10:16 AM
