you have turbo? help me..
Old Oct 9, 2003
civic-king's Avatar
civic-king is an unknown quantity at this point
i don't have turbo, someday maybe.....
i am interested in the PCV under the air plentum.(manifold)
does anyone know the size of hose this is?
i got some gp2000a's, and i need to build a bypass/turough-way for it, but all the DIY's for turbo i've looked at, don't mention the PCV. i thought you needed this for turbo somthing.
any way, i'm looking for the size of hose on PCV.
please let me know turbo guys!!
thanks
Old Oct 9, 2003
MadWheel's Avatar
Premium Boosted Member
I bought a K&N over sized breather for my PCV Valve. I still had to use a chunk of use to extend it though because the breather doesn't clear if directly mounted. Sorry I don't know if that helps or not but the larger breather from K&N has the correct size.
Old Oct 9, 2003
civic-king's Avatar
i don't think you are refuring to the correct pipe. the pcv is under the intake manifold. the one you put a breather on is a heater hose. it is also used to lube the throttle plate. by removing it, and putting a breather on, you have just shortened the life of your throttle body. good job. i never understood why people put those things on their cars.......
Old Oct 9, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
your wrong...The hose is just connecting it to your intake so you do not vent your crankcase gases into the atmosphere. It is a emissions thing...it has nothing to do with lubing your throttle body.
Old Oct 9, 2003
civic-king's Avatar
humm.....i think that was true on the 5th and 6th gen, but i think that hose just became a heater hose. and it does lubercate. i've been told that the PCV is located below the intake manifold.....that's why i was asking people with turbo to help me....
turboed owners most-likely know where the PCV is, and the size of the tubeing.....
Old Oct 9, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
ok genius.. heres some words from the know it all.....
its a crankcase vent.... not a throttle body luber... lmao .. thats sum pretty funny ****... but its
PCV IS located under the intake manifold, you cant miss it... and well theres only one of us on the site with an oil catch can connected to it.
if you wanna know the size... jack the car up LAZY.. and pull the F****ing Hose off.
man thats like asking if we know the width of the trunk.... i mean sure someone knows... but why cant u just go measure it ? LAZY.
Old Oct 9, 2003
civic-king's Avatar
why would their be two(2) crankcase vents?
that sounds odd........
Old Oct 9, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
where are there two? show me ? here's my ONE.. next to my dipstick..
Old Oct 9, 2003
zinkyroo's Avatar
cool beans
Your wrong..Its the Crankcase vent there is only one
Old Oct 9, 2003
MadWheel's Avatar
My breather looks close to Osoboosted's, only a black filter, K&N but the same idea.
Old Oct 9, 2003
my04wrx's Avatar
my04wrx is an unknown quantity at this point
by letting small amounts of crank fumes back into the intake pipe right above the TB it acts as a luber (is that a word)?
Old Oct 9, 2003
my04wrx's Avatar
i just wanted to add something. the act of letting crank case fumes vent to the atmosphere is illegal. the was because in old car that were parked on say the beach under the sun, the cabin would fill up w/ the fumes from what i'm told.
Old Oct 10, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
when you get a turbo DO NOT HOOK THAT INTO THE INTERCOOLER PIPES!!!! you can re-rout it to the intake pipe TO the turbo, but if you hook it to the intercooler pipes, you will have oil all over your engine bay every time you go into boost.
Just to give you an idea, try taking the valve cover off your car and drive it around for 10 mins.
Old Oct 10, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
is that even a sentence? lease:
Old Oct 10, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I have my PCV valve hooked to an oil catch can. And the PCV breather hooked up to a K&N breather filter. The size of the hose at the actual PCV valve (below the intake manifold) is about 1/2" ID and it redirects the gases to the intake on mine.
Old Oct 10, 2003
civic-king's Avatar
the only pic i have has too much resolution.....
do you know how i can display it? it's 51KB, so....
Old Oct 10, 2003
MadWheel's Avatar
upload it to your rides section, then just make a link that directs it to that upload, using the IMG function.
Old Oct 10, 2003
civic-king's Avatar
yeah...well...i can't figure out how to do that stuff. i would like to post pictures of my car and stuff, but i don't know how. i went to the user profile, or whatever, but i still don't understand.....
Tedverseti
Apr 23, 2020 01:45 PM
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
justcruzin125
Aug 11, 2015 09:09 PM
