Sponsored by:
Sponsored by: CARiD
Indiglo gauges lose blueness with lights on..
Old Sep 27, 2003
syndrome's Avatar
syndrome is an unknown quantity at this point
Question Indiglo gauges lose blueness with lights on..
Once I turn my car on the gauges light up a nice, glowling blue.. but then when I put my headlights on it gets hit with lights from my old gagues in the back of it and looses luster, how can I fix this? does it involve removing the old gauges?
Old Sep 27, 2003
Vinh's Avatar
oddd
Old Sep 27, 2003
XxSoVeReiGNxX's Avatar
on the guage cluster, there are two ***** that stick out. The one on the right, if you push it changes the milage display to trip meters. The one on the left if you twist it left and right, it will make the light coming out of the cluster dimmer or brighter. Try dimming the lights. The downside of this is the light on the radio buttons and other pieces of the dash that can be lit up will also dim.
Old Sep 27, 2003
syndrome's Avatar
when I do that the whole thing dims, its like the blue shuts off and just lights blue from the light behind it, i spliced into the red/black line in the blue connector like supposed to but this happens..
Old Sep 27, 2003
hmm....
you could take the led bulbs out of the cluster or mask them off. Since the indiglos provide their own light, there's really no use of the OEM face.
if you lift up the oem faces (like peel them up), you can see where the light comes from. Mask it off with tape or electrical tape, and the light won't get through. I'm planning on doing this. I'm swapping my DX cluster to an EX, and the SRS light will always stay on because its in a DX. I'm just going to put tape over the SRS slot, under the gauge face, and it won't be a sore sight anymore.
Old Sep 27, 2003
You may have wired it wrong. Dimming the stock lights should not affect the indiglos. What kind of gauges did you get? I thought all gauges would completely block the stock light from coming through.
Old Sep 27, 2003
streetglower's Avatar
dimming the stock gauges dims the needles.
Old Sep 27, 2003
Elite's Avatar
Elite is an unknown quantity at this point
you have your car wired wrong if you said that happens because my gauges only turn on when I turn on my headlights. or parking lights.
Old Sep 27, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
^^^ yea ur lights are obviously connected wrong.. they are not supposed to just turn on with the car... ur supposed to wire them to the wire that gets power when u turn ur lights on.. and as far as the light coming threw from behind... u must have really shitty ebay gauges cause they're supposed to be think enough that , that doesnt happen.
Old Sep 27, 2003
syndrome's Avatar
do you know what wire color that is, and is it connected to the blue or green plug going into the cluser?
Old Sep 27, 2003
cryption's Avatar
2003 Nissan Frontier
you can just take out the bulbs of your old ones ... its really simple
Old Sep 27, 2003
cryption's Avatar
^^^ i did
Old Sep 28, 2003
syndrome's Avatar
some of the lights are right behind the bases of the needles though, do I leave them in and just take out any other ones that dont light up that needles? And while im at it ill resplice that wire but which wire do I connect it to?
Old Sep 28, 2003
renagadecivic's Avatar
renagadecivic is an unknown quantity at this point
its the red/black wire coming out of the blue connecter you need to wire the power too.
Old Sep 28, 2003
syndrome's Avatar
thats where its connected right now and it comes on without me even turning the lights on, doesnt really bother me but I'd like for it to be done so i dont know what the hell to do
Old Sep 28, 2003
What?! really? it shouldnt be on without your lights are on, if its connected to the right wire.
HiImBrandon
Jun 1, 2015 07:34 AM
zaboomafoozarg
May 30, 2015 09:21 AM
Blazz
May 25, 2015 10:56 PM
Ma213802
May 18, 2015 07:01 AM
werdnahall
May 17, 2015 11:37 AM
