Help My power door locks don't work!!!!!!!!!
Old Sep 25, 2003
Civicly02's Avatar
Thumbs down Help My power door locks don't work!!!!!!!!!
My car's power door locks do not work. I have no idea why. I checked the fuses and everything is fine.
When my key is in the ignition doors unlock but do not lock.
When my keys are out of the ignition the power door locks do not work.
Like it has no power or something
I have no idea what is wrong with it
I have a 2002 civic ex with the factory alarm.
I checked the wires and I coupld not find anything either that is not hooked up or something
Help Please!!!!!!!!!!!!!!!
I will give points if someone can help me out with this problem
Old Sep 26, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
maybe the techies can help
--> moved to tech
Old Sep 26, 2003
LiKEaFeRiO's Avatar
Did you do this while your door was open?
The problems you described happens when you have the drivers door open. Its so you don't lock yourself out.
If not, then I have no clue.
Old Sep 30, 2003
Civicly02's Avatar
does anyone have the schematics for the keyless entry, alarm and also the power door locks for our cars. The honda dealership said that since I have some mods inside of my car it is going to cost me $215 dollars just to diagnose the problem
Old Sep 30, 2003
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
honda dealers alway find a way to void their warranty
Old Sep 30, 2003
XtremeJM's Avatar
i might be able to help you out, I installed a few alarms/remote start/window modules... just let me know, we live in the same city.
Old Nov 2, 2003
TRDragon's Avatar
TRDragon is an unknown quantity at this point
im uppin this because i have the EXACT same problem and was hopin anyone knew a solution or the cause of the problem
Old Nov 2, 2003
Novaz3's Avatar
Novaz3 is an unknown quantity at this point
my mom always said " son if you cant fix it, take it to honda dealership" just a tip
Old Nov 2, 2003
eye_see_you's Avatar
let the devil out
honda's factory alarm system uses a negative contact locking mechanism as in if its not closed it will not lock unless you do it manually. The problem seems to be a controller issue which I had on mine at first but was replaced by warranty . Regardless of mods it should not cost you unless you modified the alarm system itself.
roverben
Jan 21, 2019 05:16 PM
MamaBear2015
May 3, 2015 02:17 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
darwin-t
Apr 18, 2015 09:29 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
