Pop Trunk ? Impossible?
Old Sep 22, 2003
Mr.Modify's Avatar
Question Pop Trunk ? Impossible?
Hey i don't here to many 7thgens that have pop trunk on them>? is it impossible or is it just to exspensive to get on our Vics? I went to this one shop and they said it was like 600 dollars cause they had to weld this and that !!! SO um is it just that hard to install or what? ANybody got it? Also if your in HOuston where is a good spot to get it ?
Old Sep 22, 2003
Gryphin's Avatar
00 Hatchback Owner
pop trunk... remote open trunk? or flip-flop..... remote open you just got to have the shocks to open the trunk and the remote release... no welding... well maybe...
Old Sep 22, 2003
Mr.Modify's Avatar
I'm takling about where you have the power to move your trunk up and down from the comfort oof your driver seat!!
Old Sep 22, 2003
Gryphin's Avatar
00 Hatchback Owner
oh!!!!!!!!!!!! thats different, you would need to weld in a auxuator on both sides, and connect it to a switch located in the front somewhere.... but it can be done, just need the auxuators ( sp? )
Old Sep 22, 2003
Mr.Modify's Avatar
so do you know a shop that does that kinda work?
Old Sep 22, 2003
player's Avatar
i have been thinki9ng of this for a while, i think all u need to do is shave your lock, and then get a ram, i am pretty sure one would be enough, and then u can control it from a switch. it would make an excellent anti theft device too if you hide the switch.
Old Sep 22, 2003
Gryphin's Avatar
00 Hatchback Owner
im sure speedfetish would be willing to give it a shot....
Old Sep 22, 2003
Gryphin's Avatar
00 Hatchback Owner
and it wouldnt need to be bring auxuators (sp?) just get 2 small ones that lift like 5 lbs each, and that should do the trick, i dont think the small ones would be costly...
Old Sep 22, 2003
Mr.Modify's Avatar
yea i was thinking that to ....i mean they got a welding machine and everything!!
Old Sep 22, 2003
Gryphin's Avatar
00 Hatchback Owner
well almost everything...
Old Sep 23, 2003
Derek-CEO's Avatar
Derek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz Erthang
You don't need to weld anything.
It doesn't matter about how much weight the actuator can lift, it's about the reach.
This is very easy to do.
Old Sep 23, 2003
fine02civicgurl's Avatar
*BoY*CaR* *GiRL*DRivER*
fine02civicgurl is an unknown quantity at this point
i saw some bright green thug car w/that.... it would come open (at a stop light) and it said ".... Boys" Whatever their "name" was... in that lime green wire writing (like 'OPEN" signs are made out of). his speaker box was all glowing green. it was neat, kinda ghetto though.
Old Sep 23, 2003
Jaykuai's Avatar
ish...
gryphin:
actuator, not auxtoator.. =)
Old Sep 23, 2003
player's Avatar
ok i am thinking something like this, get an actuator like this one
http://cgi.ebay.com/ws/eBayISAPI.dll...category=42894
connect one side to the back of the trunk, and the other side to one of the arms of the trunk, get ride of the lock and extend the remote switch to the driver side.
does this look like it makes sence??
Old Sep 23, 2003
player's Avatar
another question, if the actuator is smaller then the size i want it to be when closed, will it stop automatically when the trunk is fully closed?
how do these things work
Old Sep 23, 2003
Jaykuai's Avatar
ish...
i think you have to place it "mathematical" so it will close the trunk right when the actuator line "arrives" to its closed point.. and so with the opening.
i want to do this too. But i think i will use normal linear actuators..
ricer_em2
May 11, 2016 08:09 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
sesi
Oct 1, 2015 02:03 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
