Which sensor monitors heat?
Old Sep 20, 2003
Zigen1's Avatar
Zigen1 is an unknown quantity at this point
Unhappy Which sensor monitors heat?
Lately Ive been noticing that wenever its hot(humid) my idle seems a little rough, sometimes goes way down during stops to as low as 570rpm. I was wondrin if i can trick a sensor (where to find it??) so i would have such probs anymore. Thanx!! lease:
Old Sep 20, 2003
flotsamm's Avatar
I believe our cars have a CTS(coolant temp sensor) that tells the ECU to adjust the TPS(throttle position sensor) and idle based off of the coolant temp. If the coolant temp is cold, then the TPS will raise the idle until the coolant temp rises. How you would trick it I dunno. Also you could have a bad TPS. Read this post here:
http://www.7thgencivic.com/forums/sh...hreadid=108733
BootyDo
Jun 21, 2016 03:45 PM
mistermenphis22
Jul 13, 2015 04:43 PM
ZILLA
Jul 13, 2015 04:52 AM
CivicsClass101
Jul 9, 2015 11:14 AM
Bounddyy
Jul 8, 2015 11:22 AM
