Springs with swap
Old Sep 11, 2003
Green Civic's Avatar
Springs with swap
If I were to get the RSX-S swap into my vic, would it be better to go with RSX springs because of the weight in the front of the car? Or would civic springs be fine? No point in lowering the car just to get the swap done and then have to go out and get new springs again. Thanx for any information in advance.
Old Sep 11, 2003
robbclark1's Avatar
Retired suspension supermod.
Do you plan on getting just springs or do you plan on doing springs and shocks? It might be possible to get RSX springs for the front and civic springs for the rear or custom spring rates to handle the extra front weight. I think true coilovers made for the Si/RSX would work the best.
Old Sep 11, 2003
Ya, I was thinking of going that direction. Are true coilovers for SI/RSX about the same price as civic's? I guess the back wouldnt settle as well because the weight from the rsx wouldnt be there, at least for the springs.
Old Sep 11, 2003
civicvtec1ps's Avatar
Search and Learn
tein ss costs around 1200 for rsx. i belive b&g is around 1000 as well.
check out www.clubrsx.com
Old Sep 11, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
The geometry of the suspension in all 3 cars is totally identical. In addition to that, you can special order Teins (as well as most other coilovers) with custom spring rates. You cannot use the Tein's RSX SS-P kit... but you can order Civic coilovers with RSX spring rates.
Old Sep 13, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
If I were running the RSX front axles/hubs/struts, etc I'd be looking to make the best ouf of it.
Boilermaker, I've noticed that the EP3 and DC5s are sharing the same spring rates with most full coilover set-ups (Tein, JIC-Magic). So far, anyone who's chosen to run DC5 or EP3 spring rates seem to have no problem with their D-block under the hood so I wouldn't see any way how it'd affect our cars negatively with the k-block.
Sep 26, 2023 06:44 PM
2005seTO
Aug 18, 2015 12:45 PM
OldschoolCool
Aug 17, 2015 05:05 PM
Mr.Beefy
Aug 12, 2015 04:39 PM
Curtchuk
Aug 5, 2015 02:14 PM
