i got some rear brakes!!!
Old Sep 4, 2003
HondaLuver's Avatar
Its a celebration bitches!
I just got them installed, i got them for a really good price, the only thing is that i have to buy a new rear controler arm.
i love them, my car stops alot better, the things i needed were calipers, discs, spindle, rear arms and brake cables off a si, and some brake fluid to bleed them. i didn't install them. a shop installed them.
They are in my members ride...
uploaded already... more pics down here...
go to
http://www.photoisland.com/servlet/G...ME=nooneziller
password is "blah"
If that doesn't work, go to www.photoisland.com, and log in to my albums with the following information:
Log-in ID: nooneziller
Guest Password: blah
Old Sep 4, 2003
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Man, I'd love to look at those. Where did you dig up the parts?
Old Sep 4, 2003
HondaLuver's Avatar
i bought them off a guy with a si and he did a swap for a 5 lug and didn't need them anymore
Old Sep 4, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
GOD DAMNIT.. i want a deal like that!!!!!!!
Old Sep 5, 2003
CivicHX01's Avatar
now go get some rims and show them off!
Old Sep 5, 2003
HondaLuver's Avatar
yea, thats my next thing to do... in 2-4 weeks i will get some rims
Old Sep 5, 2003
HondaLuver's Avatar
they are in my members rides
Old Sep 5, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
I'm reeeeaally curious how that affects the stock brake balance.
EDIT: I say that because if I had to brake hard, I would not want the rear wheels to stop so fast to the point that all it does is cause the rear of the car to slide. If you don't know what I mean, slam on your brakes and throw the e-brake up.
Old Sep 5, 2003
HondaLuver's Avatar
if the fronts slip the ABS will take ova... i have a ex so my car is compatiable with abs... it stops alot better and smoother, less pressure on the pedal for the force to stop faster...
trust me i love it... muahaha
Old Sep 5, 2003
All Eyes On Z
I have an EX too but even with the stock brakes my rear would slide. But now that I think about it I think that's probably cuz I had shitty rubber/bad rear camber angle. Well, to say the least from that I know the rear brakes are working, lol.
I don't doubt you one bit your car stops better, but the brake balance is very important front vs. rear in more situations than just coming to a normal stop at a light. I just have to wonder how much it would affect the balance negatively/positively in more than one situation.
Old Sep 5, 2003
HondaLuver's Avatar
humm, interesting...
Old Sep 5, 2003
keffin's Avatar
nice... but.. you never said how much???
you should but some brembos on all the wheels now, with some SEMI-METALLIC Brake Pads, and you are set!
paint the calipers if you want....but paint them black IMO looks best
Old Sep 5, 2003
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
i dont think it would affect that much since all the weight still tranferd to the front and most of the weight is ther, and it's not like out rear drums have all that much stoping power.....
rear disc brakes wouldn't do any harm...
Old Sep 5, 2003
opto_isolator's Avatar
Some questions -
1. How much
2. Did you get any sort of proportioning valve? I heard that you need that so your front's don't lose power
3. what about the e-brake?
Old Sep 5, 2003
HondaLuver's Avatar
i paid 250 from a guy who did a 5 lug conversion on his 02 si.
labor was a bill.
no i didn't need a proportioningvalve. the car use to tilt forward when i braked hard, now it stops evenly. i didn't loose any power, they work even better now
the ebrake is built into the caliper, they are off a si so their ebrake connects to the caliper.
what you have to do it unplug the abs cable and the brake lines.
detach the lower trailing arm. which holds the drum on.
take out the rear section of the brake cable which runs under the car and into the center councle in ur car.
you disconnect the old brake cable where it hooks up, that is inside the car(center cousel).
hook up the rsx or si one(same thing)
put the new si trailing arm with the spindle.
put on the discs then the calipers and hook up all the brake cables.
then bleed.
Old Sep 5, 2003
KeNsHiN's Avatar
LEVA
man what a geat deal! great job!
Old Sep 5, 2003
HondaLuver's Avatar
im planning on getting some wilwoods in front(12.3 inches) and upgrading the rears to 10.3 inches with wilwood calipers and discs.
that is the stock size of integra type R brembos...(rsx)
Old Sep 5, 2003
pleasejoe's Avatar
pleasejoe is an unknown quantity at this point
that sweet
Old Sep 5, 2003
tinman's Avatar
Damn! I gotta do that swap!
Old Sep 6, 2003
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
I did it to my car also i love the way it stops, but i have a DX so no ABS but it stops great
Old Sep 9, 2003
Just so everyone knows - you don't need the rear control arms (they are the same according to majestic honda's website)......I don't know why some of you said that you do.....
Old Sep 9, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
correct me if im wrong.. but dont you just need the rear knuckle/hub/spindle assmebly along with the rotors and calipers?
i mean.. yea you would need the si brake lines, and stuff.. but i thought that our control arms were the same...
Old Sep 9, 2003
yes - they are....I think there was some confusion by some calling the knuckle assembly the control arm.....
7thgensurvivor
38
Aug 29, 2015 11:50 AM
DAC
Jun 18, 2015 10:00 PM
MamaBear2015
Jun 11, 2015 07:33 PM
CivicHX01
25
Nov 18, 2003 09:40 PM
Andy
Dec 29, 2001 07:32 AM
