RS Lip Install Instructions
Old Sep 4, 2003
Hedonism's Avatar
Hedonism is an unknown quantity at this point
anyone know how to install a RS lip? today i got the lip and a little bag of bolts and clips. i thought i needed 2 sided tape and stuff like that. any sites with pictures that i can follow?
Thanks Guys/Gals
Old Sep 4, 2003
Hedonism's Avatar
here are the bolts
Old Sep 4, 2003
HondaLuver's Avatar
Its a celebration bitches!
i think they go on the ends of the skirt...
my front lip goes on with only 2 screws, a little too easy to steal it
Old Sep 4, 2003
Hedonism's Avatar
so i just screw it on my bumper in the wheel well? nothing under it. it came with some bent brackets i dont know what the hell they are for.
Old Sep 4, 2003
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
i put two screws on the inside of each wheel well to hold it. and i also used doubles stick tape (get the thickest u can find) along the inside of the entire lower shelf part that touches the original bumper. the fitment on the RS lips sucks- there will most likely be a gap between that lower shelf part and the black lower grill of your car. still- its tough to notice unless you look carefully. i didnt use my clips at all, couldnt figure out how to.
Old Sep 4, 2003
Vinh's Avatar
what if u hit a bump....will the kit fall off?
Old Sep 4, 2003
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
yeah,i just screwed two screws into the sides of the wheel well and usesd double sided tape. fits fine for me and its pretty much locked into the bumper.
Old Sep 4, 2003
Hedonism's Avatar
thanks guy, i get the idea now
Old Sep 4, 2003
Bogus1's Avatar
Bogus1 is an unknown quantity at this point
yup did the same thing
Old Sep 18, 2003
Alex1's Avatar
Can you take a closer pic with different angles on the brackets please?
Old Sep 19, 2003
slamtank's Avatar
slamtank is an unknown quantity at this point
does RS lip's fitness suck?
ima buy one too..
Old Sep 20, 2003
dru106's Avatar
ThE CoRRupToR
Isnt that a type B lip? Thats the same one i got. Fitment is ok, mine was tight as hell. I only used one screw on each of the inner wheel well. Other than that i really like the looks of that lip.
Old Sep 20, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
i just used two screws and 1 bolt per side i think..
i have no idea wut the brackets are for.. lol
the lip fits tight enuff so that it wont even fall off w/o any screws. but with the screws and bolts in.. its solid as arock
Old Sep 20, 2003
SkiLLzSter's Avatar
illest ma f*cken member
its so tight it scratched my OEM bumper...
Old Oct 8, 2003
becak's Avatar
becak is an unknown quantity at this point
is that mean that you have to drill your bumper?
I just got mine today, need help for installation too
Old Oct 8, 2003
Mr.Modify's Avatar
so where do you stay again? (only kidding dude)
Old Oct 8, 2003
cdmx's Avatar
hey, what you guys do if you had like 600 bucks
get a rs lip, neuspeed upper bar, tanabe underbrace.
or a Port and polish job
Old Oct 8, 2003
civicvtec1ps's Avatar
Search and Learn
suspension goodies first
Old Oct 8, 2003
02ciVike's Avatar
02ciVike is an unknown quantity at this point
Yeah the front lip is a very snug fit. It probally wouldn't even fall of with out fastening it...but I do not recomment this. Just fasten the bolts and use 3M two sided tape.
Old Oct 8, 2003
02ciVike's Avatar
Even better get the shop that paints the lip to install the lip for you they probally won't charge you to much extra for labour
Old Oct 8, 2003
alloriginal's Avatar
putang inamo!!!
alloriginal is an unknown quantity at this point
those 2 brackets go in the middle of the lip, it just holds it up better. you should see 4 holes... you don't really need it unless you scrape a lot. mine didn't come w/ any brackets.
Old Oct 8, 2003
skipbarber's Avatar
i used two screws on the inner fenders...3m double sided all weather tape on the lower portion of the bumper under the oem grill and two backstraps and screws pulling the lip onto the bottom of the stock bumper..i did it for better fitment and because it cant be yanked off without ruining one or the other or setting off my alarm
Old Oct 8, 2003
skipbarber's Avatar
another...
you cant see these at all. if anyone needs any of these brackets i have a few to sell the brackets that come with the lip are WAYYY too short to fit between the lip bottom and the bumper bottom..so i made my own
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
silentz
Jul 9, 2015 08:16 PM
fvckbg
Jul 7, 2015 07:08 PM
