RS Lip Install Instructions
anyone know how to install a RS lip? today i got the lip and a little bag of bolts and clips. i thought i needed 2 sided tape and stuff like that. any sites with pictures that i can follow?
Thanks Guys/Gals
Thanks Guys/Gals
I spent 1425 points to do this.
i put two screws on the inside of each wheel well to hold it. and i also used doubles stick tape (get the thickest u can find) along the inside of the entire lower shelf part that touches the original bumper. the fitment on the RS lips sucks- there will most likely be a gap between that lower shelf part and the black lower grill of your car. still- its tough to notice unless you look carefully. i didnt use my clips at all, couldnt figure out how to.
Originally posted by krayziebonet4l
yeah,i just screwed two screws into the sides of the wheel well and usesd double sided tape. fits fine for me and its pretty much locked into the bumper.
ThE CoRRupToR
Isnt that a type B lip? Thats the same one i got. Fitment is ok, mine was tight as hell. I only used one screw on each of the inner wheel well. Other than that i really like the looks of that lip.
2k1civic.com O. G.
i just used two screws and 1 bolt per side i think..
i have no idea wut the brackets are for.. lol
the lip fits tight enuff so that it wont even fall off w/o any screws. but with the screws and bolts in.. its solid as arock
Originally posted by HondaLuver
i think they go on the ends of the skirt...
my front lip goes on with only 2 screws, a little too easy to steal it
so where do you stay again? (only kidding dude)
Search and Learn
Originally posted by cdmx
hey, what you guys do if you had like 600 bucks
get a rs lip, neuspeed upper bar, tanabe underbrace.
or a Port and polish job
putang inamo!!!
those 2 brackets go in the middle of the lip, it just holds it up better. you should see 4 holes... you don't really need it unless you scrape a lot. mine didn't come w/ any brackets.
i used two screws on the inner fenders...3m double sided all weather tape on the lower portion of the bumper under the oem grill and two backstraps and screws pulling the lip onto the bottom of the stock bumper..i did it for better fitment and because it cant be yanked off without ruining one or the other or setting off my alarm
another...
you cant see these at all. if anyone needs any of these brackets i have a few to sell
the brackets that come with the lip are WAYYY too short to fit between the lip bottom and the bumper bottom..so i made my own
mjdiaz89
Jun 21, 2016 09:26 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
