turboing my auto lx???
Old Aug 21, 2003
slowlx2k2's Avatar
slowlx2k2 is an unknown quantity at this point
I am thinking of dropping a turbo on my auto lx but i have a few questions. I am thinking of purchasing the sf turbo kit after reading the turbo diy from catalyst. Do I need to upgrade my fue rails or injectors? Is it even possible on the auto lx?? What other mods do I need before this to make it work without breaking everything. Does anyone know where I can have this installed in the cleveland area. Iam good with cars but I don't think I have the ***** to attempt this myself. If anyone has any input before i do this please lemme know. I am turning my lx into a nice semi fast daily driver. Also one last question.. Will all this be emssion legal in ohio?? Thanks everyone.
Old Aug 21, 2003
alienmonkey's Avatar
alienmonkey is an unknown quantity at this point
Re: turboing my auto lx???
The beauty of SF's kit is that it don' use new injectors. Heard that new injectors mess you over, but not 100% sure. Fuel rail isn't needed I don't believe, but it can't hurt. For an auto people will tell you you should get a tranny cooler, but some will tell you they have been running fine without one.
I don't know anything about Ohio since I'm not from there.
Oh and one last thing, I'm sure someone will say use the search, but here is most of your info anyway (I don't feel like being a jerk today).
Old Aug 21, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
i'm running an sf powered auto lx at 5 psi...tranny slips a bit between shifts but otherwise running great...transmission cooler is not yet installed...
i did the install myself...kinda fun...
Old Aug 21, 2003
Diemos's Avatar
Diemos is an unknown quantity at this point
You dont have to do anything, just put the kit on your car. I imagine turbos cut the life of your car down quite a bit. But who really intends on keeping a turbo Civic past 150,000 miles? Also, I heard that the turbines die after 100,000 miles.
Old Aug 21, 2003
iamboo's Avatar
Retired - SoCal FI Mod
new engine = 6 bills
new turbo = 4-5 bills
but i also see your point, by the time you hit 150k on your odo, you'd probably gonna have a new car anyways...
Old Aug 21, 2003
slowlx2k2's Avatar
ohmysac... was it really worth the time and money to turbo your auto. how much did it cost you all together and would you help me install mine when I pick it up?? Do you think not having the tranny cooler is causing the slip?? also did you run it at the track??
Old Aug 21, 2003
EnProceso's Avatar
i think a torque converter would help with the shifting, tranny cooler just keeps the fluid cool so everything stays lube'd.
ohmysac, whats its like at 7-8 psi? thats what i want to run daily. also does it slip with everyday driving or when your flooring it? and uh just to put an end to a fight me and a friend is having, can you do you a burn out...like really smoke the tires?
Old Aug 21, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
^---- many people have asked me that!
I guess a burnout in an auto is a real feat!
Old Aug 22, 2003
ohmysac's Avatar
i've heard keeping the fluid cool helps the clutch plates grip better which means less slippage...i've never had it up to 7-8psi...everyday driving is not bad...when i'm hard on it it slips...say you are pushing the gas hard in 2nd gear...it gets up to about 5k and slips and you go a few hundred rpms over that while it attempts to grab unless you let off...
burnout? never tried...i'm a puss lol
Old Aug 22, 2003
XxJDMCivicxX's Avatar
I'm pretty sure you can pull a burnout with a turbo auto, handbrake and accelerate . Might have trouble with low pros, but I did it on my 1990 ex-r accord auto.
Old Aug 22, 2003
Diemos's Avatar
Mmm well the turbo doesnt spool up until what? 4,000 rpm? so I hardly see how you could use it to burn out an auto. But if you really want, drop it in neutral and rev to 7k, and drop it into drive... yes it hurts your transmission but it works.
Old Aug 23, 2003
EnProceso's Avatar
i'm pretty sure if you have a turbo you'd only be able to do that once then is new tranny time.
Old Aug 24, 2003
DINGALING's Avatar
DINGALING is an unknown quantity at this point
to burn out in a turbo, couldn't you just put the car in nuetral (like you would a manual), rev the engine up (like you would a manual), and throw it into first gear (like you would a manual), then mash the gas (like you would a manual)??? to me, it looks like it would work... just make sure you kick it into d1.
-DINGALING
jdawgzcivic
17
Feb 1, 2020 04:16 PM
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Sep 27, 2015 11:33 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
