wiring rear turn signal lights to stay on
Old Aug 10, 2003
MYK1013's Avatar
I'm not sure if this is the write forum to put this on.
Can anyone tell me a way to keep my rear turn signal lights on so it will just start blinking when I use the turn signals.
Like the turn signals in the headlights, they stay on and starts blinking when I signal.
Old Aug 10, 2003
XtremeJM's Avatar
dual filiment bulbs
Old Aug 10, 2003
R1Style's Avatar
That is definatly more complicated then just putting in a dual filament bulb. It can be done but you have to do some serious wiring. Unless you know a lot about that stuff, I say stay clear.
Old Aug 10, 2003
Elite's Avatar
Elite is an unknown quantity at this point
its basically the same with the blinkers in the front, they are dual filament stock, i changed mine to single and now it only turns on when I put the blinker. Very simple just change the bulbs.
Old Aug 10, 2003
hankscorpio's Avatar
hankscorpio is an unknown quantity at this point
That will not work at all. the turn signal lights aren't on all the time like they are in the front, thats what he wants to do.
Old Aug 10, 2003
There are a couple of ways to do this, and one does not require a dual filament bulb at all. Basically all you would need is a relay and to do some rewiring back there. You're gonna have to know some wiring stuff to do this. If you do it like this it will basically be on all the time and then just blink when you put the blinker on, and turn completely off and on during the blinking sequence( not like the stock front blinker where it blinks brighter and not as bright)
Old Aug 10, 2003
XtremeJM's Avatar
Trust me its not that difficult, I did it about a year ago, all i did was took the harness (from a 7thgen at the junk yard) from the turn signal in the front with a dual filiment bulb,k so its identical to the front turn signal and just spliced the wires from under the dash from the front and ran the line to the rear, and tada. It took me maybe 15-20 minutes, but then again i practically rewired my entire car since I am very familiar with vehicle wiring, so yeah. I dont really like the look of it so instead of me unwiring everything, i snipped the wire from the light bulb. So its not any "serious" wiring, just can be slightly time consuming for such a small job.
Old Aug 11, 2003
MYK1013's Avatar
Ok, let's say I want my rear turn signals to be just like the front ones. (stays on and just get brighter, dims, and brightens and so on......)
So all I'll need is replace stock with a dual filament bulb?
Is there a dual filament bulb available that will fit in the stock turn signal harness?
I'm not really fond of messing with the car's wiring, so I'm trying to do this the easy and safe way.
BTW, thanks for ALL your replies.
Old Aug 11, 2003
Blv's Avatar
Blv
Blv is an unknown quantity at this point
replacing the bulb with dual filament WILL NOT work at all, because there's no current going in to the bulbs when the blinkers is not on, you need the wire that current to the dimmer second filament
I have a dual filament on my turn signal, but haven't done the rewiring yet
Old Aug 12, 2003
MYK1013's Avatar
Ok, So how would you wire a constant current to the dual filament bulb??
Old Aug 12, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
splice it in with your parking lights assuming the fuse wont blow
Old Aug 12, 2003
MYK1013's Avatar
Can anyone "second" what OHMYSAC said above?
"splice it in with your parking lights.............."
Old Aug 14, 2003
MYK1013's Avatar
ANYONE?
Old Aug 14, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
i did that.. but then every time i hit the blinker.. the car beeped and all the lights on the dash flashed like the hazards were on. lol
Poopies
Apr 20, 2017 11:36 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
Pir8pete
165
Mar 6, 2009 05:16 PM
GhettoCivic
Nov 12, 2001 03:15 PM
