Good Place to Ground Wire??
Old Aug 6, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
Hey Guyz,
Where did everyone ground the wire for their reverse indiglo gauges? I had used electrical tape to tape it to the big metal thing but I guess it came ungrounded last night cause only my needles lit up.
Thanks,
Eli
Old Aug 6, 2003
abmerop18's Avatar
Jam out with your clam out.
i wrapped it around the screw on the left side that the cluster uses to screw in. i wrapped it around it and screwed it in tight over it. works perfect. the screw touches a metal bar which is grounded, so it is perfect and no drilling is required.
Old Aug 6, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
I had that originally and then somewhere said thast real dangerous and can blow something or something. I dunno, and then I couldnt get it to wrap around again so i taped it down .
Ill go try again...
Old Aug 6, 2003
abmerop18's Avatar
never heard of that. i dont see what it can blow. its only a grounding spot. its not like you are connecting any postive wires to it.
Old Aug 6, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
Thats what I said- I didnt believe it but ya never know. I just grounded it to the screw. Didnt take long at all. Thanks.
If anyone else knows anything about grounding to a screw being bad, lemme know.
Old Aug 6, 2003
LudlamTheory's Avatar
i boogie for the raindrops
ground all you want to a screw, jsut dont tape it on, thats ghetto... if you wanna do it correctly, it costs about 50 cents... you need a ring terminal, and a self tapping screw... if you cant figure out what to do with them im taking away your priveledges to play with wires
Old Aug 6, 2003
skipbarber's Avatar
^what he said
crimp a ring terminal on it. and screw it on to something metal. you can also wrap it around a screw all you want...it wont kill you or your car. it wont damage anything, whoever told you that is wrong.
SoyerOner
May 11, 2015 09:46 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
LikeWh0a
Nov 27, 2001 04:24 PM
wawacito
Nov 5, 2001 03:32 PM
wsking77
Aug 30, 2001 12:32 PM
