Sponsored by:
Sponsored by: CARiD
Magnaflow exhaust question??
Old Aug 5, 2003
02SilvCiv's Avatar
02SilvCiv is an unknown quantity at this point
I plan on installing the magnaflow catback exhaust. would you guys reccomend putting on stainless steel exhaust clamps or just the regular clamps. and am i right to say that the size 2 1/4 inch clamps. and if there are anyother tips you have it will be my first time installing an exhaust.
Thanks
Old Aug 5, 2003
Jeff's Avatar
Jeff is an unknown quantity at this point
I would just use the ones provided by magnaflow until you drive to the muffler shop to get it welded. The clips hang low to the ground even if you turn then to the side.
Old Aug 5, 2003
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
exactly what Jeff said..... get a them welded..... if you lower you car as little as an inch, you'll be scraping speedbumps, driveways, etc. with those clamps....... welding them also allows you to have the pipe sit a bit higher too.... good luck, it's a great exhaust system and i've loved it ever since....
Old Aug 5, 2003
02SilvCiv's Avatar
Thanks for the info. would you guys happen to know how much a muffler shop would charge me to weld the system.
Thanks again
Old Aug 7, 2003
Jeff's Avatar
Mine only charged me 30 bucks.
Old Aug 7, 2003
kempster's Avatar
kempster will become famous soon enoughkempster will become famous soon enough
i'm sure this is a retarded question but do u mean weld the exhaust pipe where the clamps would be instead of using the clamps, cause i have a magnaflow exhaust and my car is lowered with godlines and it scapes all the time
Old Aug 7, 2003
flotsamm's Avatar
Yeah, remove the clamps completely and have it welded instead..
Old Aug 7, 2003
GreenNVicious's Avatar
Newbie
Yeah, I can personally vouch for that
Misfit2613
Jul 30, 2015 09:49 AM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
hayden55
Jul 8, 2015 11:38 PM
fvckbg
Jul 7, 2015 07:08 PM
