Can I wire a 4 Ohm DVC sub like this...
Old Aug 4, 2003
syndrome's Avatar
syndrome is an unknown quantity at this point
Question Can I wire a 4 Ohm DVC sub like this...
My friend got a 15" sub (Kicker comp VR) and was going to bridge his 4-ch amp into the sub for its power, but because its 4 Ohm DVC it can only be wired to single 2 and 8 ohm loads.. and I don't think bridging into 2 Ohms is safe for the amp (Crunch 4175). So is it possible to bridge both channels into both VC's and power it like that? If not, how should he wire it?
Thanks.
Old Aug 4, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
Think of that DVC as two separate speakers. He needs to bridge each side of the amp. Then run each side to a single voice coil. Just be sure to put the gains at the same level for each side.
Old Aug 4, 2003
syndrome's Avatar
Yeah each DVC pair can be considered as a speaker.. but do you mean he should just connect a VC together with wire then run 2 bridged connections into the other VC?
Old Aug 4, 2003
Regularjoe's Avatar
The amp should have 4 speaker outputs and the sub should have 2 voice coils.
Two for channel #1 and two for channel #2.
Take the two outputs for channel #1 and bridge them. Wire this to one of the coils on the speaker.
Take the two outputs for channel #2 and bridge them. Wire this to the other coil on the speaker.
Old Aug 5, 2003
LudlamTheory's Avatar
i boogie for the raindrops
doing this correctly usually requires a multimeter to match levels and get things to work right
sch2cm
Jul 21, 2015 09:58 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
Jul 12, 2015 11:54 AM
robbie374
Jul 7, 2015 02:56 AM
