Power Locks Dont work after HU Install
Old Aug 1, 2003
AntiLoop's Avatar
AntiLoop will become famous soon enough
HELP !
Just installed a deck in my car witha friend.
When I got home I realized my Power Locks dont work
both in the car trigger and remote control.
What could be the problem ?
Old Aug 1, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Well, first i would check all my fuses. If those are all fine, i would pop off the bottom part of the dash where the 12v outlet is and check all the wires that are attached to the little black box that's on the right side, bolted to the steel bracing. Thats the keyless brain. Other then that i wouldnt have a clue.
Old Aug 2, 2003
ptechricer's Avatar
ptechricer is an unknown quantity at this point
Mine did that too, but I had somebody do it for me all it was a loose wire behide the radio. Well that is what he told me anyways.
Old Aug 3, 2003
Yeah. If it's not the fuses, check to see if any wires may have come loose during the install.
Old Aug 3, 2003
LazyDog01's Avatar
Raceway Park Track Tech.
u checked all fuses the ones under the hood too and under the steering wheel..one you might wanna check if you didnt. is back up 10A fuse under the hood.
Old Aug 4, 2003
Boiler_Room's Avatar
Boiler_Room is on a distinguished road
Check the fuse for power locks under the steering wheel, it's labeled. I bet you popped a fuse doing the electrical work. It happens to me all the time. I'm in an out of Radio Shack so much they offered me a job there. Let us know how it goes...
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
MamaBear2015
May 3, 2015 02:17 PM
ORskier
May 3, 2015 12:54 PM
darwin-t
Apr 18, 2015 09:29 PM
ademarco6
Exterior
Nov 15, 2001 09:36 PM
